washing a drivers suit?
Old 10-07-2006, 08:58 PM
ChasNMe
ChasNMe's Avatar
Default washing a drivers suit?
i got it at johnny o's auction at road atlanta last weekend. it is a stand21 suit from last years krohn racing/trg grand am team. do i send it out to the drycleaners with any special instructions? or can i put it in my machine at the house? thanks, jake
Old 10-07-2006, 09:17 PM
BuckeyeZ06
BuckeyeZ06's Avatar
Dry clean only; no specials instructions needed.
Old 10-07-2006, 09:49 PM
danswofford
danswofford's Avatar
According to a rep at G-Force just machine wash and drip dry.
Old 10-07-2006, 09:56 PM
redvetracr
redvetracr's Avatar
My wife has been washing my suit in the washing machine after every event and letting it drip dry in the shower for years...still looks great!!
...redvetracr
Old 10-07-2006, 10:27 PM
fcarga
fcarga's Avatar
Machine wash-gentle cycle- in cool/warm water using an ounce or so of Woolite-no bleach, no fabric softner. Can machine dry on air or low temp on gentle or delicate cycle or you can hang and let air dry. Same for socks, underwear etc. The inside of the suit and the underwear etc, if Nomex, will turn yellow after some period of time-sooner if exposed to sunlight, but this apparently doesn't effect it's fire resistance. You can also dryclean, but I worry about which chemicals are used and the garment care provided by the cleaners.
Old 10-08-2006, 12:32 AM
xsiveone
xsiveone's Avatar
If you dry clean, you run the risk of the dry cleaner impregneting the suit with flamable chemicals that would defeat the purpose of NOMEX.
Old 10-08-2006, 02:22 AM
ChasNMe
ChasNMe's Avatar
gentle cycle wash cool, drip dry in the shower, thats what i'll do
thanks guys, jake
Old 10-08-2006, 08:18 AM
ErnieN85
ErnieN85's Avatar
thanks guys, jake
Guys I'm a drycleaner it's not so easy.
Most times this will be the best.......however if it's greasy drycleaning is the only way it will come clean. Now that said if its sweaty washing is the only way it will come clean, so the way to go is first determine if it's greasy or not and if it's old grease because if it's been washed the grease is likely permanent! New grease Dryclean in Perclorethelene (doesn't burn) or CO2 then wash!
Old 10-08-2006, 06:59 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
10 bucks dry cleaned and done.
Old 10-08-2006, 09:03 PM
danswofford
A rep at G-Force says that the company is wary of possibly flammible dry cleaning chemicals binding with the suit fabric and rendering the fabric less fire resistant than it should be.
Old 10-08-2006, 09:20 PM
ErnieN85
ErnieN85's Avatar
Exactly why I specified the solvents I did!
To washing a drivers suit?
Quick Reply: washing a drivers suit?
