ANy Before/After #'s with a 4 Corner Balance?
St. Jude Donor '08-'09-'10
I put my z06 a set of scales today. Didn't have time to complete the job but got some initial corner weight numbers.
Car had been lowered so the base numbers are meaningless. Hoping someone may have done a 4 corner balance and has before/after numbers.
With 3/8 of a tank car weight was 3150, front to back was 52/48%. Corner weighting was way off but I don't know if GM is driven by this in factory setup or more to equalizing ride height front & back.
Intersted in any feedback from other experiences.
make sure those scales are level or the #'s mean nothing. 3/8 of a tank will make the left rear heavy as all of the fuel is in the left tank... GM doesn't give a crap about corner wieghts...........Dont forget to put the drivers wieght in the car.
What, does the gas tank empty right and then left? I thought with a tank close to half I would be fairly nuetraL fluid wise.
Scales were level. Guy who owns the shop where we did it races and build cars, midgets, etc.
Car was also cross jacked quite a bit. I did manage to balance that out. Just like to compare some numbers and see what a stock setup is like if possible or a corner weight after a balance.
Originally Posted by UstaB-GS549
Should tanks be full for corner weighting?
Originally Posted by RAFTRACER
When I scale they are either empty or full...........the drivers wieght is in the vehicle and at least one sway bar end link from the front and the rear are missing........
Frank Gonzalez
Live and learn. Sounds like no use adjusting without adjustable endlinks for swaybar.
Makes me wonder how many shops corner balance stock suspension C5's without the adjustable links!!
I dont know chit about the numbers you guys are talking about but after Dan lowered, balanced and aligned my car, I took 6 seconds off my lap time at Putnam this past weekend.
1 Post
Cruise-In VIII Veteran
You can corner wieght without endlinks.......you will just end up with large amounts of preload in your sway bars.
Account disabled by user request 2 March 2009
Originally Posted by gonzalezfj
Danny is on the ball, as always. You will need adjustable sway bar links so they can be adjusted to neutral after the corner weighing is finished. Make sure one of them is disconnected while corner weighing and you have the equivalent driver's weight on the seat. We use old rotors as weights.
Frank Gonzalez
Frank Gonzalez
They also know how to account for the gasoline tanks and driver weight. Very impressive bunch!!
Hey Danny, did ya ever get my PM???
Bob
Cape Cod Bob,
Your name, yellow Z06 and address look familiar. I think that we were at Phoenix/Palm the same day having the same work (corner-weighting and allignment) done. I'm the guy with the Silver 03 Z06. I followed the advice of those in the know and went where they did--the Pros at Phoenix. My ride is now much more predictable and precise. Aside from the work I had done there, I also got great, low cost "private lessons" in things Corvette.
Bob 33
Bob 33
Originally Posted by mlongo99
Won't that end up changing the ride height?
RaftRacer:
Do you shoot for pretty much equal weight on each wheel?. I am showing 52/48 front/back with a 3/8 tank of gas.
I would like to know what a stock Z06 looks like on the scales.
Corner weighing only moves the weight from one diagonal to the other. You want those about equal for a track with an equal number of right and left turns (if those exist). Some also try to set the front wheels equal for better braking. Corner weighing will not change the front/rear weight distribution by more than a few lbs, and that will be mostly due to the suspension fore/aft movement.
Ride heights are set separately from corner weighing based on the desired ground clearance, suspension kinematics and aerodynamics.
Originally Posted by Chalky
RaftRacer:
Originally Posted by Cape Cod Bob
I went the easy route and had Phoenix Racing do my car. Had to get adjustable end links for the job to be done. The C5 adj. end links work just fine on the C6 Z06.
Bob
Bob
Yeah, I'm lazy too and let Phoenix do my cars. Either Phoenixville (Mark) or Palm (Kurt) can do a first-class job.
Frank Gonzalez
