Some C2 questions.....
Does anyone here solo / autoX a C2?
I'm new to the part of the forum and mostly hang in the C2 section.
I have a lightly modified 65 that I have done a little autoX work with....neither it nor I will ever be real competitive but I would like to see about stiffening it up a bit. It is a convertible, and I don't have or want to go with a cage. I would like to just reduce it's tendancy to flex and if possible maybe reduce some of the cowl shake when it is on the road. I have heard that filling the frame rails with a rigid foam is a trick sometimes used to firm things up, anyone ever heard of this or done it....
I was also told there was a book called Chevy Power or similar that had some suggestions for frame mods that could be done to have things out.
Not looking to go crazy here but if anyone has some experience with the C2, I'd like to hear about it.
Darren
Darren
When I had my C2, I found that the roll bar with a front brace (removeable) offered the best handling. Other than that you can gusset the rear kick up on the frame--just before the rear wheel, the front clips can also be gusseted and the solid rear spring mounts. If you do not have power steering, that will be you best handling solution and an aftermarket or later corvette steering wheel (14-15"). I also transformed a 81' corvette seat to fit the drivers side and made slits for a 6 point harness--autocrossing and hpde. Carrera used to make HD shock, I believe they still do, along with the F41 suspension. Otherwise you can convert to a late model front and rear fiberglass suspension from vette brakes. Also, 15x 8.5" wheels and all purpose tires like Nitto NT-1 or Kumho V700 for better grip. This should get you started.
Gordy is right on all counts, but if you don't want to run with a cage, make sure you run with the hardtop firmly bolted in place. You can pull the body off and weld the frame rails if you want to get crazy. You can install a Greenwood 5 link rear susp. while the body is off or if you don't want to take the body off the frame, a Guldstrand 5 link bolts in w/minor modification. Make sure your dog legs (frame kick up in front of the rear tires) are strong and free of major rust.
Three other mods, Steeroids, carbon fiber drive/half shafts, and 17" wheels (w/the larger brakes that fit in them). OK that's 4.
Do half this stuff and you will have a car that rides as well as a new one and will handle with all but the most heavily modded ones. /:\
go to the C-3 section...Corvette frames from 63-79 are basically the same, and look on ebay for an OLDER copy of the Chevy Power book. (newer ones didn`t have a Corvette section).
.....redvetracr
.....redvetracr
BTW, you didn't mention how original your car is. If it's not too modded yet, given the value of C2's these days, it might not be a bad idea to prep a frame and drop your body on it (I bought an epoxy coated 75-77 frame for $900 at Carlisle this year. You may need to modify some body mounts).
Thanks guy for the info....
My car is what I call lightly modified...my rule is I like it to look stock to the casual viewer and no changes that can't be easily undone in case I have to sell it (as mentioned they price is getting up there but it has always been my toy/fun car) I have offset trailing arms and wider tires on 17 inch rims. Uprated swaybar in front (1 inch maybe even 1.125 been awhile since I played with it) I used to have a rear swaybar, but I was not over happy with it and the new offset arms prevent it's use. The car has been lightend somewhat with various AL replacement parts and unneeded stuff removed...I need to get it weighed but I expect it is maybe 100-130 lbs off of stock.
I might consider the rear frame change as I always felt the flex was worst right at that rear kickup....but can it be done given the C2 body?...it seems like the body prevents exactly the same bracing that the C3 had...as I recall the C3 is 'different' behind the seats.
Guess no one liked my foam filler idea...
Anyone know of a rear bar that will fit the C2 with the offset control arms....or someplace in SoCal that might do a custom setup? I don't want much in the back maybe 7/16.
I have talked to Gulstrand....I have most of their recommendations in place...sadly had to get rid of the spherical bearings in the rear with the new arms but figured poly bushing with wider tires was a better trade over skinny tires and the bearings.
69autoXr you will be getting a PM...
Darren
Darren
Email sent, the file is 8MB, LMK if there are any problems receiving.
