Toyo Pressure question
I'm running Toyo RA1's and wanted to know what if at all is the best pressure to run those tires at. I ran Car Guys last weekend and hot pressures were 38 & 39 psi. Car handled good but from some of the track guys that I spoke with they say that might be a bit low. Any suggestions??
Location: DFW This user does not support or recommend the product or service displayed in the ad to the right
I've found the RA-1s to get slick/greasy if they get above about 40 psi hot. Therefore you need to bleed them down depending on your conditions. For autox I run 35f/31r, COLD. If I'm going to a DE I'll probably drop down a bit from that.
HTH, and have a good one,
Mike
Mike
Immediatly after hot laps. I was debating adding some to bump it up to 40 psi but the car handled very well so I was wondering if it's worth it or not??
