Drilled and Slotted brake rotors
Old 10-24-2006, 09:00 AM
BLACK SHARK
BLACK SHARK's Avatar
Location: In the shop most of the time,,, And it BEER TIME somewhere
Default Drilled and Slotted brake rotors
I have a question about the Drilled and Slotted rotors that are for sale on a auction web site. My question is what kind of quality are these for under $150 for all 4 rotors. Anybody using these?
Old 10-24-2006, 09:23 AM
gpm30236
gpm30236's Avatar
those are for bling, drilled can create a weak spot for cracks to develop , do a search there are many posts on rotors.
There are numerous sources for cost effective replacement rotors such as Rock auto / Napa , who have new rotors for $16- 20 each .
Old 10-24-2006, 12:22 PM
AU N EGL
AU N EGL's Avatar
Not on this section of the forum. Crack too fast. Drilled and Slotted are for bling, not performance stopping.
Old 10-24-2006, 12:58 PM
vettmike
vettmike's Avatar
Stay away from drilled rotors, they tend to crack, slotted rotors will crack also, just not as fast as drilled rotors.
vettmike
Old 10-24-2006, 02:08 PM
Lancer033
Lancer033's Avatar
most of us mange to crack solid rotors on a regular basis, drilling holes making them weaker isn't going to go over to well here.
Old 10-24-2006, 07:04 PM
BLACK SHARK
OK, What is a good pad and rotor combination for some street driving and some weekend road course blasts?
Old 10-24-2006, 07:06 PM
BLACK SHARK
vettmike
Glad I checked before spending any$$$$
Old 10-24-2006, 07:48 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
NAPA 28 ea search NAPA on this forum
Old 10-24-2006, 11:17 PM
BLACK SHARK
Thanks John, There is some helpful information there.
Old 10-25-2006, 07:20 AM
AU N EGL
AU N EGL's Avatar
NAPA rotors
part #s
86700
86701
86702
86703
Old 10-25-2006, 08:39 AM
varkwso
varkwso's Avatar
Rockauto - same rotors - 19 + shipping
there is usually a rockauto code floating around for another 5% discount on this forum if you ask for it...
I buy them 3 sets at a time....
Old 10-25-2006, 09:23 AM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
I long for the day that drilled and slotted rotors go away like white letter tires. Ask any structural engineer about how notches and holes cause failures in brittle materials. It is like a Junior level undergrad common knowledge. The holes in the fuselage of the 737 you call windows all have doublers around them to compensate for the holes.
Old 10-27-2006, 10:11 PM
BLACK SHARK
OK, After reading dozens of posts on here for the last few days there is something I dont quite understand. Now bear in mind I am not an aerospace engineer, BUT I have seen on this site that plain rotors, not drilled ,not slotted, have a cracking problem as well. Some guys talk about buying 3-4 sets at a time. Some theroy on the cracking problem is from rapid cooling of very hot rotors. Many of the posts have stated the cracks are mainly on the outter side of the rotor because of cool air hitting the rotors when the car is parked back in the pits after a session. Is that right or wrong. My question to those who have had a rotor crack, is it mostly the fronts and do you cooling ducts on your cars. Is there any visual way to see if there is a problem before a crack occurs?
Old 10-27-2006, 11:56 PM
Sidney004
Sidney004's Avatar
Mine crack always in front, always on the outside.
Old 10-28-2006, 01:05 AM
BLACK SHARK
Do you see anythink other than heat check on them, or bang and you toss on another set? Are yours plain, or drilled-slotted?
Old 10-28-2006, 01:23 AM
rcolling
rcolling's Avatar
I have seen this post hundreds of times.
Drilled/slotted rotors are BS according to all of these guys.
1) if you don't race then the bling effect is real.
Get them and enjoy the heck out of them.
2) done right driled/slotted rotors rock.
Check out the new Z06 rotors. Drilled, slotted?
If you don't race then you can get just fair quality drilled/slotted rotors and have no problem. My Brembos have been great.
If you do race then you had better buy the best. Guess what? They still are drilled and slotted.
Old 10-28-2006, 01:26 AM
BLACK SHARK
What are the Brembos priced at?????
To Drilled and Slotted brake rotors
Old 10-28-2006, 01:34 AM
rcolling
rcolling's Avatar
Mine have been on for several years.
Here is a much more recent post for Brembos at $340....
http://forums.corvetteforum.com/show....php?t=1529797
Old 10-28-2006, 07:40 AM
larryfs
larryfs's Avatar
Then why you structal spans like bridges have holes in structal members? I-beams I have seen solid, and with cutouts...
Old 10-28-2006, 07:48 AM
John Shiels
Bridges don't get to 1300 degrees. Strucutral memebers are made it be light for material cost, erection, transportation cost and it would also reduce wind load on the bridge.
Quick Reply: Drilled and Slotted brake rotors
