***ECS Brake Duct Cooling Kit***
From the tech section.
It looks like a nice setup using DRM ducts and their own, ECS, spindle kit ...
$368 -> http://forums.corvetteforum.com/show....php?t=1532289
St. Jude Donor '05-'08
I was surprised by how much of a difference the brake cooling setup makes. My brakes at WGI never felt better. All day long it was the same feeling and a small plus - no cracked rotors unlike last time where we had 3 crack rotors.
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
Originally Posted by Adam Boca
how much for just the spindles and the hose?
The spindle piece alone are $169 for the pair.
Doug,
What size hose is required? I would prefer to use your spindle kit with the C6Z06 ducts, thus saving nearly $200. The Z06 ducts are 2.5", but I imagine I could make a 3" hose fit if need be.
Thanks,
Mike
Thanks,
Mike
Originally Posted by M_Minnick
Doug,
Thanks,
Mike
Thanks,
Mike
The DRM duct and our spindle piece is 3", but I'm sure you could crimp it down to 2.5". Just pull some of the wire out of the hose.
Former Vendor
3.5 inches is what we sell with our kits. Back when we did all of our testing, before releasing our brake ducts. 2.5 inches was too small for track use.
3.5 necked down to a 3 inch spindle duct will work just fine because it's packing air into the center of the rotor.
Randy
Randy
Randy
Randy
Aaahh what do you know
(I just checked and our spindle piece is 3.5" also):o
Here's a link -> http://www.aircraftspruce.com/catalog/appages/sceet.php
Originally Posted by Bink
There is excellent duct available at Aircraft Spruce - tip your hat to John Shiels.
Thanks again Bink,(and John) link saved
