Negative toe number= toe OUT, Positive= toe IN?
I mean the numbers you get from an alignment machine print out...
I'm pretty sure I have it right, but need to verify please...
MD
MD
Several emails with Michael on this topic today. I had originally gotten some of the relationships backwards. Hopefully the comments are correct now. If anyone else cares to review, it's here:
http://www.corvetteforum.net/c5/toom...6alignment.htm
Originally Posted by acrace
Are you sure you want toe-out in the rear (moderate/aggressive non-OEM values in the table), as well as the amount of toe-in for the front?
Can't speak for aggressive, collection of what I've read here with some feedback from David Farmer.
Originally Posted by Highroller
Will these numbers work for an 03 Z06?
Am I right or have I gone looking at this too long?
Michael D.
Not taken as pestering, all good discussion. I want to make sure the comments are accurate. As for the values, I have experience with the Moderate column, since the days of my '02 Z06. Can't speak for Aggressive settings, will need input from the hard core racers here.
I found good information in these articles.
http://www.articlecity.com/articles/...cle_1606.shtml
http://www.articlecity.com/articles/...cle_1600.shtml
http://www.articlecity.com/articles/...cle_1607.shtml
Originally Posted by Z06-Nomad
Sorry to keep pestering. In my experience, the more aggressive the alignment, the more toe OUT (-) in the front and the more Toe IN (+) in the rear. From what I see, the notation at the bottom is now correct, but the actual values for toe only have the correct number but the reverse or incorrect sign (pluses should be minuses and minuses should be pluses).
Michael D.
Michael D.
I doubt that you want to run toe out in the rear in either autocross or lapping days in a C5 or C6. What Z06-Nomad says is what I was questioning in my previous post.
