Exotic Muscle Harness bar install
I just bought a used Exotic Muscle Harness bar for a late C4, and I was wondering if anyone had a picture of one installed. Since it is used, it doesn't have any hardware or instructions, and I'm not 100% sure what all interior pieces I have to remove to install it.
I looks like the two upper arms bolt onto the upper seat belt mounts, but I'm not really sure.
I had the exotic muscle harness bar. It was a tough piece to install but once it was in it was nice. It was a very tight fit in my car. I had to work at it to get it aligned. Getting over the studs for the rear was the hard part. I am assuming it is still the same. The rear section bolts in the place where the inside roof mounts bolt down, using the same bolts. I had to cut the carpet slightly but when I took it out the roof mounts covered the cut in the carpet. The other section bolted to the seat belt bolts and the seat belts were mounted back in place.
I dont have any pictures but it really only fits one way. Hope this helps
Mat
Mat
Mat
Mat
