Corbeau Forza seat install
Can someone lead me to a post that describes a Corbeau (Forza?) seat installation. It has some excellent photos but I've managed to lose the link. Thanks
If you use the Corbeau mounts it's very easy. Remove stock seat mount nuts, remove seat(after diconnecting power seat connectors if you have them), remove seat belt receiver from seat and attatch to Corbeau mount(if you aren't using a harness or you drive to the track), attatch seat to mount, install seat on stock studs and tighten nuts. Voila.
Thanks but ..... the problem is positioning the sliders on the Corbeau seat bracket. There are two sets of holes to attach sliders to bracket - the earlier post I had seen described how one set of holes didn't work as well as the other set. And I can't remember which set was the good set!
St. Jude Donor '10-'11
