Anyone go from a C5 to a C6? Thoughts
I've read a lot about C6's being twitchy compared to C5's on the track.
Anyone have first hand experience?
Easy to fix?
What are the biggest differences in handling and overall feel?
I just looked and saw what used C6's are going for
Easy to fix?
I did...but had to miss two track weekends due to some issues. my next weekend scheduled is not til Dec. I am in the process of finding a track only car, so maybe I will never have the new c6 on the track to really find out the difference.
CI 3-5-6-7-8 Veteran
Originally Posted by ghoffman
I have driven a bunch of C5's, have driven 1 C6 ZO6 (mine) and I think the C6Z handles (alot) better. I can't speak for a standard C6 compared for a C5.
1 Post
Cruise-In II Veteran
Originally Posted by Cobra4B
So you're saying that the C6 Z handles better than a prepped C5? How? I mean the chassis is inherintly the same setup.
St. Jude Donor '07
Never had a C5, but I would definitely describe my C6 as twitchy under heavy braking. Coming down from high speeds the car is just a handful. Maybe I don't have the setup right, or maybe it's the driver (probably the driver) Otherwise, I find the car develops fantastic grip and is well balanced.
Also, it is my opinion that the regular C6 is down on power to a C5Z despite their similar ratings on HP. I don't hit the tech/performance section too much, but based on light reading I think a stock C6 dynos at about 340-350 RWHP as opposed to 380ish for a C5Z. My experience on the track re-enforces this. I will have mine tuned to remove the TM "feature" and might toss a few bolt ons this offseason.
Those are my excuses and I'm sticking to them!
CI 7-8 Veteran
St. Jude Donor '07-'08-'09
I'm no expert, but have an '04 C5 w Auto.
Test drove an '02 C5Z with performance mods and a C6.
To me the feel of the C6 was in a totally different class.
I felt the C6 was a lot smoother.
I've had my '05 C6 on the track and am really pleased with it's performance.
Certainly am still learning have a lot more to learn about driving, but after i got hooked on track events a couple of yrs ago , i have a C5 vert, not a good track car, also had one of the first C6 Z51's, took it to quite a few track days, noted that it felt like my lexus sedan compared to the C5 so instead of doing track upgrades on it i got silver, an 01 Z06 and am happy as can be the car is responsive, communicates well with me, and always puts a smile on my face, The C6 was fun, but felt numb like it was isolating me from the track .
Easy to fix?
Easy to fix?
After 6 track events this year I wouldn't say there is much difference in the handling, just the HP.
Thanks for the input.
I'm at one of those points where I put money in my car and basically am thowing it away...yes I know putting the money in a C6 is the same but the well isn't as deep
I can fetch 22K for my car I'd guess being reasonable. Heads/Cam(400rwhp), headers, huge stereo(all MB Quartz speakers w/ solo baric sub 1600watts), cage, harnesses, all Z06 bits, Cavaggio rear fascia, Corsa Indy exhaust with E-cutouts, HID's, Motorsport Wheels, very annoying super duper alarm, Honker, basically every single thing that can be done. Chassis has 78K but the motor was a brand new out of the box installed dealer 04 with probably less than 20K on it. Suspension parts have less than 20K on them and all the work was professionally done.
The car had a 408 iron block that the original owner wanted to keep so they popped in a 04 long block with lightly ported heads and a cam. 918 Springs, Harland Sharp Rockers, all the bells and whistles.
I really want a TT car again and pouring 10K into this car just doesn't make as much sense as doing it to a C6 considering the creature comforts I'd pick up.
I can buy a very quiet easy to drive C6, put on a TT kit, some tires and pads and go out without the rumbling car I have now and probably go just as fast if not faster and have more fun.
. I don't recall ever seeing a STOCK C5Z dyno at 380.
Your car looked somewhat twitchy braking for T1 at VIR last month, but my C6Z (and Jody's car) did essentially the same thing at that spot. I don't think it's a C6 problem, but rather a track surface problem (ripples) at that particular spot. In my experience, if you are on ABS over the ripples, it upsets the car.
Your C6 is certainly nailed down around the rest of VIR, at least looking at it from my car.
Frank Gonzalez
Frank's right, my car is squiggly under hard braking, particularily at T.1 at VIR, too. It kinda feels like a covey of quail is fluttering in my azz, it's not unpleasant, rather refreshing, in fact! My car has done that since day 1, but it seems to be manageable, just a little funny feeling. His C6Z had some rearend movement under braking going on too. Must just be a characteristic of these Vettes.
BTW, Matt, most of the ECU stock C5z's are somewhere between mid 350's to low 360's from all I been able to ascertain. There might be another ~8hp available with a tune.
This C5 to C6 topic is pretty timely. The day for me to make up my mind on what to do with my car and my track future is coming within the next few months. I have to decide whether to go W2W (NASA) in a caged car, trade for a C6 or something compatible, or just quit entirely. The C5Z is a fabulous car for the track. It is well sorted out, the weak points have been identified and solutions found. I can't imagine going through that process again in a C6 or something else, but I'm going to need to do something.
St. Jude Donor '07
It's probably just me being a sissy with the braking then, my previous car was rock solid no matter how bad you screwed it up under braking. Of course it wasn't quite as fast either.
You know you want a C6Z Jody-you and Rob can pimp them in his Renegade; Team Miller Lite!
St. Jude Donor '07
Originally Posted by gonzalezfj
Matt, the C5Zs I have seen (quite a few) dyno more around 355-365
Frank Gonzalez
Frank Gonzalez
Hey how did you fair in the straights against that real fast black (supercharged?) Mustang? I've got some footage of both of you clowns leaving me for dead in the back straight...
If it were a strict track card I'd just stick with the C5, but this is also my DD in the summer.
The wife likes the car but likes the C6 in Orange better...plus if I'm starting fresh I can do TT's, some simple suspension mods and keep it quiet and driveable.
No more wincing when I start the car in the garage with the windows rattling and clothes smelling of exhaust
I have one other matter for us to take care of that is outside of the cars. Once thats done I'll be putting up the C5 for sale. Hopefully sooner rather than later since I'd like the entire winter to find the right deal.
Originally Posted by gpm30236
.....The C6 was fun, but felt numb like it was isolating me from the track .
Maybe it is because I have a lot of seat time in a C5 but the C6's I have driven lacked "driver feedback". The C6Z definitely has the beans to back up its looks and is blistering fast on a road course - while the brakes and tires hold up ( a problem shared with the C5).
C5s are definitely the cheaper track option and a C6 Z51 is not really a contender for the C5Z - stock to stock - in what I have seen. But C6's are being built today with new car warranties and that lovely new car smell...
Being a research kind of guy I am willing to set up an exhaustive set of tests at all the finest locations to determine "the best" - just as soon as I can locate a compatible fund cite....
