Engine Oil Cooler hose & fitting size?
St. Jude Donor '07
I am a little unclear as to proper hose size for engine oil coolers...
Someone mentioned;
"Anytime external lines are used for plumbing engine oil, -8 is marginal for short runs and few/no bends. -10 is average and -12 is preferred."
in a post at http://forums.corvetteforum.com/show...R-1+oil+cooler
However I was talking with Tom Dewitt (Dewitts Radiator) and he said "#12 is WAY to big for something that only flows a 2-4 gpm. GM used 3/8 (#6) lines on the C6 (2005) with EOC."
The reason I asked Tom is because he is the one who made my custom radiator with an integrated engine oil cooler...
Talked to another shop who sells aeroquip products and they recommeded -8 hosing...
So what size is it?
To the main reason in deciding is the radiator fittings for the integrated EOC are 3/4-16 (#8 sae) straight thread o'ring seal fitting. 3/4 is about the same size as -12 from what I understand. Nobody seems to carry and adapter fitting that goes from this size to a -12 hose, but they do for -10 and smaller... I just want to make sure the hose size and flow is correct for my track use application. Keep in mind the engine is not highly modified...
Some feedback on what others are running would definately help...
Also I notice many running air coolers run a thermostat so the oil does not stay too cold. Would this be necessary with an integrated EOC within the radiator? I would think not since it will help warm the oil faster, but keep it cool when need too...
Someone mentioned;
So what size is it?
I'm running -8 lines for my 45000 btu external cooler (stock LS-1, 317 rwhp). I measured the oil pressure before/after and found a 1-2 psi difference from 1000 to 5000 rpm.
I've not had any problems with low OPs when at track temps. I honestlly think that people go with -10 hoses just because "bigger is better", not any measurable differences.
Obviously modded motors may need bigger equipment.
HTH, and have a good one,
Mike
Mike
...redvetracr
St. Jude Donor '07
Running the hoses...
Anyone have any C4 pictures of how you ran the hoses from the oil filter adapter to your EOC? Am looking to see how you kept it within the body area as so not of it hangs down below it.
As to finding longer hoses, most places sell it $ per foot and you can buy just about any length you want.
I don't have any pics, but on mine, I routed the lines from the sandwich adaptor (-10 lines as supplied from DRM) directly forward along the block, past the PS pump, and cut a hole through the driver's side of the radiator shroud just forward of the three relays.
Mine is also a '96
Mine is also a '96
Originally Posted by qwik96GS
...#12 is WAY to big for something that only flows a 2-4 gpm.
that an LSx oil pump flows? My understanding is that a SBC flows
more in the range of 8 gallons per minute at max RPM and I am
unaware of the LSx engines being substantially more efficient in
the lube dept..
Smaller lines are easier to plumb and add less weight. But fittings and
hose lengths contribute to pressure drop in the circuit - if the
measured or anticipated pressure drop is unacceptable, larger lines
ought to be used.
Keep in mind that flow rises with RPM. The test is not whether
pressure drop is adequate at 77% of max RPM, the proof is that
flow is adequate at 100% of max RPM.
Another thought is that if choosing to run the smallest line possible,
it isn't enough to rely on what works for someone else unless you
exactly duplicate their configuration. Hose runs or fittings may mean
the difference between adequate lubrication and failure.
One rule of thumb is to anticipate a 5 PSI drop for every sharp 90º, 2
PSI for every 45º. Where there is a choice, extending the hose is
better than inserting an angled fitting. This R-o-T dates back to the
days before many of the newer fitting designs, so fancy fittings may
result in lower pressure drop, but it is still illustrative.
If I intended to test pressure drop, I would try -8, otherwise I would
use -10 as a minimum.
exchanger - on startup, engine coolant will gain heat faster than the
oil and help the oil come up to operating temperature more rapidly.
So a thermostat in the oil line of an oil/water exchanger would be
redundant, IMO.
I use a Mocal thermostat in the oil line of an oil/air system.
another thought is that if choosing to run the smallest line possible, it isn't enough to rely on what works for someone else unless you exactly duplicate their configuration. Hose runs or fittings may mean the difference between adequate lubrication and failure.
One rule of thumb is to anticipate a 5 PSI drop for every sharp 90º, 2 PSI for every 45º. Where there is a choice, extending the hose is better than inserting an angled fitting. This R-o-T dates back to the
I vote that the thermostat is not necessary for an integral oil/water exchanger - on startup, engine coolant will gain heat faster than the oil and help the oil come up to operating temperature more rapidly. So a thermostat in the oil line of an oil/water exchanger would be redundant, IMO.
Most unregulated engine oil coolers (whether integrated or external to the radiator) will only allow the engine oil temps to get up into the low 100s during daily driving (it needs to be around 190). Even with my thermostat I have to run a cover over the cooler for daily driving (thermostat always passes a minimum of 5%).
No flames, just info.
Have a good one,
Mike
St. Jude Donor '07
I can't imagine the coolant temperature being that much cooler in the radiator than in the block. Perhaps slightly different, but my temps range in the 205-215F range on the street. Even if there were a 20 degree difference it still would be within proper oil temp range.
I asked Tom DeWitt's opinion on it to see what he would suggest.
Sent: Sunday, November 12, 2006 8:02:02 PM
Subject: Re: Intigrated engine oil cooler hookup?
A thermostat is used with air type coolers because you have no control over the ambient air. It could be a variable of over 100 degree (0-100f). With internal cooling the water temperature isn't going to vary that much, maybe 190-230. Not enough to worry about over cooling.
You don't have to put the t'stat inline at the very beginning. Just watch your oil temps. On the LS-1 they need to be around 190; not too sure about the LT-x engines.
However, you need the oil to be at least around 170 or so to dry out the condensation you get in the crankcase from normal blow-by. Otherwise the water will mix with the oils and form acids. This is one of the reasons a short-haul drive mix (where the engine oil doesn't get up to temp long enough to dry out) is considered a hard-use environment.
In any case, let us know how it goes!
Have a good one,
Mike
Have a good one,
Mike
St. Jude Donor '07
Great advise everyone and it is truly appreciated. Just bought some dummy 1/2" rubber hose to test and plan where the lines are going to run. With the Radiator EOC the hookups are on the passenger side. Doesn't look too difficult to get it there, but I like the idea someone gave me about using rubber hose to prior to using the real stuff!
This is the most common misconception that I come across. The
engine coolant temperature is measured in the engine, not in the
radiator. High performance radiators are very efficient. As
such, in normal street driving it will be much cooler than the engine
coolant, and will cool the engine oil too much. Only when the coolant
thermostat is fully open will the radiator coolant be close to the engine
coolant temp.
coolant temp.
oil/water heat exchanger mounted in the radiator. As VetteDrmr
points out, the coolant in the rad takes longer to warm up
than the coolant that recirculates in the engine.
As the engine coolant reaches the temperature necessary to begin
to open the thermostat, only a portion of the engine's coolant
is exchanged with the radiator before the thermostat closes.
On cold days, this cycle repeats continuously with the rad always
being decidely colder than the engine. Even on hot days with
high demand on the engine, the cycle occurs several times before
the engine side and the rad side of the cooling systems begin to
approach equilibrium and the thermostat remains open constantly.
My comment about a thermostat being redundant for oil/water heat
exchangers would only be applicable for coolers that are plumbed
into the engine side of the cooling system. The coolant would
heat up rapidly to operating temperature, helping to warm the oil.
This is how jet boats are configured as well as one car I know of.
The L98 oil cooler works this way, too, I believe.
Fluidyne Therm-Hx Fluid Coolers p/n DB-30500
Incidently, C&R offers a nice blend valve p/n 1037000010
used coolers like the OEM one GM offered with towing packages for
BBC pickups and found it suitable for summer use in the climate here,
covering it in the off-season except, say, when pulling sleds in the
mountains. A temperature gauge being my guide as to when to
cover or expose the cooler.
Based upon that I should have seen approximately a 25 psi drop
(1 45 fitting (2 psi), 6 90 degree hose ends (guessing at half the 5 psi
drop you mention). Again I measured only about a 2 psi drop.
and one reaps as one sows.
With 6 x 90º fittings, 1 x 45º fitting, perhaps 10' of hose, the cooler
and an adapter at the block, a pressure drop of only 2 psi seems like
a very good achievement. When you tested the drop, did you use two
gauges with one plumbed before the adapter leading out to the cooler
and one after?
My remark about 77% was prompted by the 5K RPM figure in the earlier
post (typo?), 6,000 RPM is getting up there.
I did qualify the Rule of Thumb by noting that it predates many of
the fittings available to us now. Below are different examples of
fittings that we currently have to choose from. Someone who didn't
know any better might think that the first item is equal to the fourth
choice.
Weatherhead Male Elbow
Perma-Cool PRM-15158 1/2" NPT
Earl's Performance Plumbing 1/2". NPT
Earl's Performance Swivel-Seal Hose Ends -10 AN
I have been looking again for up-to-date figures about flow or pressure
drop without success. If anyone can provide references, please do so.
You need to understand why decisions were made
to determine if the install works for your situation.
obvious location. Words to live by ...
No flame perceived. If anything, my initial tone was provocative and one reaps as one sows.
With 6 x 90º fittings, 1 x 45º fitting, perhaps 10' of hose, the cooler and an adapter at the block, a pressure drop of only 2 psi seems like a very good achievement. When you tested the drop, did you use two gauges with one plumbed before the adapter leading out to the cooler and one after?
I also remembered that, in addition to recommendations from others, I went with -8 lines because they're 1/2 inch ID, larger than the galleries within the engine itself.
In any case, I've had no problems with low oil pressure during my autocross/track days. Idle OP with oil temps around 250 range around 18-20 psi, up in the high 30s on track (when I have time to look).
Have a good one,
Mike
St. Jude Donor '07
On My Dewitt radiator both the inlet and outlet of the EOC is on the passenger side of the radiator.
The run from the oil filter adapter and up over the power steering assembly to the fittings on the radiator fittings does not require any sharp bends and only 2 - 4' hose lengths. Simple enough to add a thermostat if needed.
