C6 suspension question
I owned a Z51 C6 for a while during the early introduction in '04, now thinking of getting another. One reason I sold it, I felt the suspension needed some work, and there was just nothing available. From posts I found searching the site, it appears VBP now has several springs available, not sure about shocks or bars. I was generally pleased with the car, but on track, I felt it needed some combination of stiffer springs and bars, especially in front. And a stiffer spring probably needs different damper valving. Given the many combinations of variables between components, I am interested to find out if there are yet any proven packages around?
you could set the car up with VBP springs or coil-overs from LGM. All comes down to $$$$$$$ unfortunately. Also depnds how important sreet ride is to you.
