Seat Harness
Life Time NCM #2196
Seat Harness
All of you Autocross guys, I am having a wolf 6pt roll cage installed. I will be keeping my sport seats and I want to know what type of seat harness is available and where to buy them from
Check out Crow seat belts --- www.crowenterprizes.com. They make a full range of 5 and 6 point harnesses that are SFI rated. I prefer their "cam lock" rather than the lever type. It is a very easy twist of a **** to undo and a click to lock like a seat belt to latch. Prices are reasonable too. Order direct.
Al
Received 8,928 Likes
Whichever brand you buy (I use Simpson) make sure you do not wrap the sub belt over the front of the seat cushion. It either goes through the cushion to a mount under the seat or you buy one of the mounting kits that has you sit on the sub strap (BK, Hardbar).
Bill
Bill
St. Jude Donor '05-'08
as mentioned in the other thread - BK sub-mount brackets is the way to go. Sets the sub-belt in the proper position and is an easy install. Here is the link to the install
http://forums.corvetteforum.com/show...ar&forum_id=23
1 Post
Cruise-In II Veteran
The Hardbar lap belt bar is very easy to install and in addition to having an even better angle for the lap belts, it also has provisions for the sub belts for either a 5 or 6 point harness. Please see following post for details.
http://forums.corvetteforum.com/show....php?t=1550605
