Tow Vehicals and low sulfer fuel
Frick'n new Laws for Jan 2007.
Desiel fuel trucks produced AFTER Jan 1 2007, must have all the new polution controls too only use the NEW low sulfer fuels.
So what is going to happen to all the Desiels now?? can they use the new low sulfer desiel? or will there be some convertions so they can use the new low sulfer fuels.
St. Jude Donor '07
All the deisel guys got up in arms about this. It is nothing to even spend 1 second worrying about. The new emissions equipment requires this fuel or it will get trashed really quick, '06 and older trucks don't have the emissions systems that will get screwed up. My '06 Duramax doesn't run ANY different on the low sulfur stuff. As usual, it's just another thing that poeple flip out over for no reason because one person on the internet has an issue. Drive on!
Cruise-In VI Veteran
Not that it will affect you guys but us in the trucking industry are screwed. This is entirely different but when the screw with our fuel it hurts bad. When they first came out with "low sulfur fuel" a few years ago, I had to replace 2 fuel pumps due to the lack of lubrication in the fuel. Now with the even lower standards and the new emission control devices its going to be interesting. A couple frinds of mine have the new engines. I have a 2006 standards enging and I get around 5.5 MPG avg. Not great but livable. These guys are getting 3.5 MPG right now. RGranted the engines are new and need to be broken in but thats ridiculous!!! On a bad day my engine when new got 4 MPG. Friggin EPA.
I heard that there was a study done and the results were that the average gasoline powered car puts out way more pollutants than any deisel. I need to research this. Anyone have any data?
You guys with your pickups and duallies will be fine. If you know anyone that owns their own truck and are thinking of buying one, tell them to buy a 2006 standards engine.
Bob
Bob
Bob
Bob
Too me, this is no different than the people that are trashing the new Z06 because of a few pointed and rare engine failures. Ahh, the bad edge of the internet.......
As for emissions, more or less isn't really something you can compare. They simply put out different emissions. The particulate coming out of a deisel is much higher though, as are NOx emissions.
Joe
Remember back around '94 when the last time they dropped the sulfer content in fuel? The media reported on leaking O'Rings and fuel pumps dieing left and right but when you looked a bit deeper you found most were lacking a lot of TLC or had 100 to 200K miles on them. At the time I was driving a '92 Cumins and never noticed a differance, other than the price jump! I'm sure this round of lower sulfer will turn out much like the last one.
1 Post
1st of June 06 the new fuel was mandatory to be available so you probably have been using it for a while now. Most fuel stations don't have the extra tanks to have both.
New fuel is 15ppm sulfur, stuff we had been using is 500ppm. The new '07 engines have a particulate filter in the exhaust that chokes up if it uses the old stuff. Big $ repair.
Winter or summer I add diesel fuel additive to my Detroit Diesel Series 60. 10 dollars of Howes product treats my 300 gal tank . It prevents gelling in winter and increases lubricity all year round. I've been told low sulfur fuel will not harm an older diesel. The new big diesels are down on power with the new regs. I see the new diesels as 1975 gas engines that got their catalysts. power went down but look where we are now on 91 octane. Give them a few years.
It happened in '96 when Detroit added cats and EGR's, Dodge dropped HP & Torque with the Cumins. After a year or two the numbers started climbing again. Just add '07 to the list of '96 fuelers not to buy.
pickups still make more power but Cummins and Ford did bump the size of the new motors
Ultra Low Sulphur diesel does have a slightly lower btu value which will result in a 1-2% increase in fuel consumption. At work we have backup generators that our safety documents require. They have to provide power for a minimum period of time in case of an outage. We recently received a bulletin from the Department of Energy advising us tha ultra low sulphur diesel is lower in btu content than current diesel. DOE required us to caluculate how long our backup generators can run on a tank of ultra low sulphur diesel. Since it was lower in btu content we needed more fuel to meet our minimum run times.
I did a little test on a recent trip to Houston and back towing my car trailer. I found my fuel milage was down by a little over 2% compared to the same trip last year on low sulpur diesel vs the ultra low sulphur diesel now available. I always run 70 mph on cruise control and I made the same fuel stops as last year. Three on the way down and three back.
So bottom line is with the ultra low sulphur diesel you pay more per gallon and it takes more gallons to get there.
Most stations have already switched. Look on the pump for the MANDATORY sticker indicating whether it is dispensing low sulphur diesel or ultra low sulphur diesel.
Originally Posted by ghoffman
How many gas stations will have this new fuel?
I think that is all that is produced now so they all have it.
my local stations have been using Low Sulfur for a long time, but the ULTRA Low Sulfer isn't here yet. My wife has a TDI Jetta (40mpg) for her work commute, and I'll definitely take note of any performance/consumption changes when the new fuel arrives.
My 99 powerstroke started to leak fuel last week which turned out to be the seals on the drain valve on the fuel filter. The parts guys at Ford told me they only sold a couple over the years and the last few months they sold 45 of them. They felt it was caused by th low sulfer in the fuel. I don't know how true this is.
