Nitto RII v Toyo RA-1
Mountainbiker2 may have his numbers reversed, a possible result of the thin mountain air. I'm now on my second set of RA-1s and know this tire pretty well. I consider the RA-1 to be the best track/street cross-over tire. It has a full tread depth of 8mm, a reason why some shave it to 4-5mm before tracking it. Full tread, the RA-1 is a bit squirmy under heavy braking, but escapes the chunking of some cross-over tires such as the VictorRacer at full tread depth. Also, the tire gives good, progressive feedback before letting go. Also, it has tread across its full width. The RA-1 would be a good everyday tire for the Vette, especially if someone else is footing your bill for these fairly soft, fast wearing tires.
Bob 33
Bob 33
I believe it is actually the same company who makes the tires!?!?
I don't recall for sure but heard that from several folks in the know.
The 1/2 second I verified on two sets of each. The thing is though shave the toyo's and they are about 1/2 second or so quicker.
So same tires, I noticed same traits in handling. Although I did notice the Nitto's got up to temp quicker.
I can't contrast the Nittos and Toyos because I have driven only the Toyos. Both seem to be made by the same outfit and both have similar wear numbers (100). In the NE and SE where I drive I see many RA-1s but few if any Nittos. Nitto seems to be best known for their softer sidewall drag radial, not their stiffer sidewall road track tire. Before I bought the Toyos I did a lot of research on several forums about contrast between these two tires and did not find good comparative data, thus, the indirect responses to the initial question.
Bob 33
Bob 33
My information is 2nd hand: I have a autox buddy that has run both RA-1s and the Nitto 555R2s (think I got that right). He says that they're virtually identical, which makes sense due to the tires coming from the same manufacturer.
If it were up to me, go with the ones that are less $$$. BTW, I've run both Victoracers and RA-1s, and while the Victos may be better at the start, the RA-1s are very consistent up to the bitter end. The Victos tail off pretty quickly after about halfway through their life.
HTH, and have a good one,
Mike
Mike
Bob 33
Bob 33
Steve
The Toyo website posts RA-1 tread depth as 8 or 7mm, depending on size, much deeper than, for example, VictorRacer with around 5mm. Any deeper and they would be really squirlly under braking. Snow tires? Also, as noted above, they don't show the cycling effects of comparable tires, running great right down till they are slicks. I hate having to toss them because of rain-fear on the street when they are in their prime on the track. They are now stored in my basement, with my winter tires now mounted, PS2s.
Bob 33
Bob 33
