C3 Autocross Car
C3 Autocross Car
Anyone built a C3 for autox? I know I've seen at least one somewhere on this forum (it had a rollbar). I've had two C3's and I'd like to get another one and autox it. What sort of mods are best? C3 is still one of my favorite body styles. I'm currently using my C6.
Thanks,
Tom
Thanks,
Tom
I built my C3 specifically for autocross, and mostly to the NCCC Group 2 rules. What mods you make depend on who you're going to run with and in what class. Tires obviously make the biggest performance increase, and the lack of available 15" sizes in the most competitive DOT tires pretty much forces the C3's out of stock classes right off the bat. Kumho offers the V710 in a 225/50-15, but other than that you're left with Hoosier DOT bias Street TD's in three 15" sizes, but for the most part these tires will not hang with the 710's or the Hoosier A6's. From there you're forced to upgrade wheel sizes to get competitive tires, then the usual suspension mods (springs, shocks, bars), power upgrades (most legal C3's will be running 70-spec LT-1 motors), and make it as light as possible within the rules.
ey 69autoxr I'm building my '81 up for SM2 slowly but surely.
First off, what shocks/springs/sway bars are best? I'm gonna definitely go to the vb&p front monoleaf eventually, but what composite rear spring and shocks go together best?
I'll be looking in to some 17" TTII copies from discount tire in the coming months and I think that'll help a TON, obviously.
Any idea how stiff the 9 leaf FE7 spring in the '81s are? My '81 has the gymkhana suspension, and it's pretty much torture driving on it. It has a 1 1/8" bar up front an like a 3/8" pencil in the back stock.
I'm thinking herb adams approach to the C3 is probably more practical, for a c3, with the lighter springs and stiffer bars. However I think tires will still be the main factor of holding enough lateral gs.
On shocks, I'm still kinda tossed on Konis and Bilsteins. The advantage I'd have with bilsteins are that my mom works right next door to them.
I can't say what's best, as I haven't tried everything. I can only tell you what has worked for me thus far. I run cut 550 coils in front and a VBP 420 lb/in composite rear spring. 1-1/8" bar in front and factory 7/16" rear bar, though most C2-C3's do not use any rear bar. Shocks are Koni red Classic SA's.
Goodyears are crap, though, and they aren't in 27" diameter. Until I can completely devote my vette to just autocross I have to run street tires. If I were to spend money on race tires I'd probably just use Hoosiers, anyways. $200 a piece and you KNOW they're good.
I currently use 275/45-16 Hoosier A6 radial or Street TD bias on 16x11 all the way around. The car is very neutral with a very slight push at the limit.
The soft spring/big bar approach may be a better compromise for a car the sees double duty street/track. But the stiff springs maintain the suspension geometry better, which for a C3 is very poorly controlled through the suspension's travel.
It all depends on your application; those Goodyears are a medium hardness compound road race tire, and would probably not work very well for autocross where you need a tire that gets up to temperature quickly. However, for a track day, those tires would be more appropriate than a Hoosier A6 would be. Also, most autocross classes except Prepared and Modified require DOT approved tires.
No idea on the 9 leaf, but i thought that the springs with fewer leaves were stiffer.
Would it be worth it to me to go with the dual mount rear spring and the monoleaf front suspension with 1 1/4" and 5/8" sway bars for sort of a dual purpose car? It'll eventually mainly be just for autocross but who knows how long that will be, until I get a good daily driver. My understanding is that the dual mount rear spring has an adjustable spring rate. I'm guessing that coupled with smart struts would give the best rear suspension geometry possible without modifying the hell out of it to fit a 6 link. I know the front monoleaf system is adjustable so that'll easily make it more comfortable to drive around.
