Reduction pulley install advice needed?
I just took delivery on a used reduction crankshaft pulley. There are no instructions with it regarding installation. Can anyone walk me through an install?
CI 3-5-6-7-8 Veteran
www.ls1howto.com is your friend.... the install instructions are very specific w/ the torques, procedures, and using a new bolt.
I had socket failure once (real similar result to a rusty bolt breaking off) and I sometimes even plan for such an event (check the possible vector for obstructions). 240 is not too bad to get though...
just slide a jack handle over a breaker bar, and give it a tug. 60lb x 4' bar, or 50lb x 5' bar. Pretty easy to approximate.
Make SURE you tighten with the old bolt, then install with new one and use LOCTITE
