Change Z06 brakes
Change Z06 brakes
I'm curious how many guys have changed the brakes on the C6Z06s. Not pads, I mean upgraded the whole system- calipers,rotors and lines fronts, rears or both. And what system did you go to. JD
I experienced excessive front rotor heat and fast front pad wear running Carbotechs all around at HPDE's. The rear pads had minimal wear. The issue is not stopping power with the front brakes, it's about getting them cooled. Also, the thin pad thickness results in quick pad wear and too much heat being conducted to the calipers. BTW, the stock brakes are phenomenal on the street, in my mind it's only a hi-speed road course issue. Autocross should not be an issue as well.
I am in the process of installing a Stoptech St-60 big brake kit for the front wheels which includes 14" 2-piece rotors. I'll be running Hawk DTC-70 front pads and DTC-60 on the stock rear brakes. I am also installing the LG spindle ducts.
John
John
1 Post
Cruise-In II Veteran
John
John
We use and sell a C6Z kit. The caliper we use is the superb Performance Friction (PFC) zR33 Grand Am spec caliper with 21mm thick pads. This caliper has 2 piece pistons for heat isolation for the fluid, and a bridge design that allows pad changes in 40 seconds! It is advertised as the stiffest 2 piece caliper of this size. It is a billet CNC caliper that is nickel plated. For rotors, we have our own 14 inch rotors that are the lightest available, a FULL 10 pounds lighter than the stock left side only stock rotors. They use billet CNC hats, AN (aircraft) hardware, custom Coleman rotors that are heat treated and balanced. You will not find a better system anywhere, and it is 100% made in USA.
Gary Hoffman
Hardbarusa.com
603-682-8073
Adapter bracket:
1 Post
Happy New Year! We have a very cool system out soon, that will allow you to use this caliper with a modular adapter that allow 12.5, 13, 14, 15 inch rotors. This means you can run $25 NAPA rotors at Lime Rock, and big rotors for NHIS, Pocono etc. The only issue is wheel spoke clearance. This caliper is wide, you need about 2.5 inches from the rotor face to the inside of the wheel spokes.
I know Stoptech is good at balancing the brake by varying the piston sizes. In fact I just learned that their rear Z06 kit has 14" (oversized from OE's 13.4") so I wonder how they would size their rear caliper to balance the system.
Are you going to do the same and what are the piston size of C5 (front and rear) and would your caliper (bores) causing any balance issue for C5 or Z06?
