but the mn6 is a better road race trans, as the gears are tighter and you lose fewer revs. HOWEVER, if you use 5th gear (most stock-geared C5's don't at most tracks), the M12 is better
GM totally screwed this up, imho. We need an OEM trans with the mn6 1-4, and the m12 5-6.
