car shakes at 65mph plus.
I need some help. My car shakes real bad at speeds above 65. At first I thought it may be the tires and since I had a set I wanted to put on the front I tried that. It is better than it was but still has a problem. The car is a 96 with 40k on it. The rotors where turned a couple of months ago. My guess is the steering rack,ball joints or wheel bearings. Is one more common than the other for that age and milage of a car? Also since it looks like I will be taking the front end apart and upgrades I should plan on while it is apart. The plan is it it is the ball points I would go ahad and lower the car at that time. I did use the car for 5 solo events last summer and have been told that it is hard on the bearings.
Could also be a bent wheel. When you replaced the tires did they do a normal balance or a road force measurement balance? A normal balance can easily miss a bent wheel.
You can make basic checks of the suspension by jacking one front wheel off the ground and checking for lateral slop (pull/push on wheel from 3/9 clock positions) and vertical (12/6 clock positions). If you find slop, then investigate further.
I'd eliminate the wheels first.
HTH, and have a good one,
Mike
Mike
Your shaking problem could be one of quite a few items.
1) wheel / tire out of balance F or R
2) wheel / tire out of round F or R - radial belt separation or flat spot
3) bad suspension part - tie rod end, worn ball joint
4) worn steering rack
5) drive shaft out of balance.
check each item out individually and you will probably find one of these is the problem.
I'd almost bet it is tire/wheel related, even though you've checked them. Could be driveshaft as stated, as it spins with car speed (unlike C5/C6 which spins with engine speed), but unless you've hit something, it wouldn't unbalance itself.
Thanks for the info guys. I was leaning towards the tires at first however the back ones are new and I changed the front ones since at first I felt that was the problem. I am checking the u joints tonight and hope to have the tires rebalanced by a better shop. How much play should the steering rack have in movement?
