AZ Speed Harness Bar Question
If you are running an Arizona Speed Harness Bar, could you tell me if I need floor-mount belts or Bolt-in belts? I picked up a pair of Bolt-in belts, but should I order the floor-mount clips to put on the belts? Thanks in advance.
Not certain exactly what you're meaning, but my AS&M bar came with two cross bars that bolt to the seat hard points. Those cross bars are drilled to let you use the trapezoidal metal harness ends. I just throw my belts behind the seat when not in use.
As far as clips go, you can use them if you want to keep the belts out of the car, but you don't have to.
HTH, and have a good one,
Mike
Mike
Does it allow for the belts to be mounted vertically? Reading about the proper installation of the Simpson belts I have, it states that the trapizoidal metal ends need to be mounted vertically. Since I will be drag racing with my Z06, it has to pass NHRA tech, which also requires this, from what I have been told.
BTW...Bolt-in, the ends have a single hole on the metal end so it can be bolted to the bracket.
Floor-mount, the ends have what looks to be clips, so you could use a metal eyelet to attach the belts to.
TIA!
TIA!
I have the ASM bar, and I use floor mount Simpson lap and sub belts. I installed the lap belt kit from Brey-Krause. The shoulder belts are wrapped around the bar though without clips. They stay in the car tucked behind the seat when not in use, but the lap and sub belts come out.
