Tell me what you think about these alignment specs
Location: DFW This user does not support or recommend the product or service displayed in the ad to the right
2005 C6
Front
-1.4 camber
7.39 caster
-.05 toe
Rear
-.85 camber
0 toe
Front
-1.4 camber
7.39 caster
-.05 toe
Rear
-.85 camber
0 toe
Yeah, i have not had any time to drive it that way but, I think I may have them go to 0.0 toe in front.
btw, do it yourself. Unscrew each rear adjuster 2 "flats". This will yield just under 1/8" toe in.
A "flat" is the amount of one wrench turn, or 1/6 turn.
How much is -.05 as displayed on my alignment sheet
in inches. Anyone have a conversion table for that?
You've got it backwards. A little toe-in helps with rear stability. Toe-out out back would make it fairly crazy.
Here's what I have:
Front: -1.1deg camber, -0.06deg total toe (out)
Caster: 7.5deg RF, 7.9deg LF
Rear: -0.9deg camber, 0.08deg total toe (in)
7500 miles, fourteen 20 minute sessions at Thunderhill, four autocrosses (twenty 45 second runs?), and the tires look to be wearing evenly... stock Z51 tires.
Here's what I have:
Here's what I have:
Here's what I have:
Is that way to much?
Edit: I just wanted to note again that I'm no alignment whiz and this alignment of mine is just the starting point from the shops asking me what I intended to do with the car. This alignment has worked out okay for me for the combination of driving I described above.
