C4 alignment Q's.
Location: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
C4 alignment Q's.
I've searched and haven't found anything definitive for a C4.
'95 coupe with the FE1 (soft) suspension, C5 brakes and GS wheels. The car pulls left right now, so I need an alignment. If I'm having it done, I might as well have a custom alignment done.
I'm looking for a good streetable autoX/HDPE alignment. Something between "full track" and the tire-friendly OEM setup. I've seen people recommending 1.5 degree negative camber front, 1 degree rear. What about toe and caster?
This link: http://www.vbandp.com/instructions/h...ruct/align.htm had been posted before. I use the "Advanced Street" settings on my 87 for autocross and occasional track days. I have 275/40-17's on the car and it is not "darty" at all for normal street use.
I noticed an immediate improvement at the first autocross after getting the car aligned with these specs. I have not seen any sort of abnormal tire wear even with changing tire pressures for autocross and track days.
I run Hoosier A3S05's for autocross and Kumho Ecsta MX's for summer street use and track days. I do play with tire pressures but for street use, 35psi is the base pressure I run.
I recently had mine aligned at a local shop that's really into racing. I actually got to help the alignment tech with it and we discussed the purpose of the car before we got started. I autocross a lot during the summer and daily drive the car. I told him that I don't mind buying tires every 16 months. So we went with -1.5 degrees of camber on all 4 wheels, 7 degrees of caster, and I forget the toe specs, but it was just slightly in on the front, and i think no toe on the back.
Dial in as much negative camber as possible. Consider yourself lucky if you can get -1.5. The most I could get in my left front(without any machined spacers) was -.8. After installing offset lower control arm bushings, I was able to get to -2.2 on that wheel. Rear camber about .5 less than what you have in front.
Yes, they are, the ten of them that I had all had about .4 degrees difference between the left front and the right front. The left was usually about -.8 degrees and the right was generally around -1.2 degrees. The difference is in the frame tooling...
St. Jude Donor '05
Sounds good- I'll tell him that.
I used the VBP Advanced Street last year in HPDE and on the road. There was no abnormal wear. I'm going to use the Autocross setting from now on, track and street. If you have have your tire pressure off even a little there will be abnormal wear quickly at the track.
E
