Need help on sub-belt mounting.
I am new to the do-it-yourself thing, so please forgive the simple questions.
I bought Corbeau seats with double locking sliders and Corbeau 5 point harnesses which come with Zero instructions. Where do I anchor the sub-belt? Is my only option to put another hole in the floor? I have NO experience fabricating stuff so should I break down and take it to a shop? I've tried searching the forums, but I had no luck. Any help would be appreciated.
Cheers from Arizona
Cheers from Arizona
Contact the manufacturer for their recommendation. I am sure that they have diagrams etc. of the best / preferred method of installation. The floor is really not strong enough to anchor a bold without a large bearing plate to spread out the load . One method that I have seen is to use a piece of angle iron between the rear seat hold down bolts and anchor the sub belt to it and run it up through the seat.
Hardbars Lap Belt Cross Bar has provision for your sub belt. Nice product......here's a link, go to the bottom of the page -> http://www.hardbarusa.com/page_options.htm
