C4 camber mod with upper control arm spacers?
St. Jude Donor '03 & '05
I read somewhere and cant find the mod where the 18mm and 9mm bushings are swapped? on the upper control arms to gain camber for better cornering.
Anyone know this mod, and have pictures? Sailor proof pics , so I can do it. Thanks, Steve
1993 C4 FE1 with ZO7 bars and shocks, springs coming later, and Grand SPort tires/Wheels.
We also shimmed the rear of the K member in with the shimms that go in the stock control arms.
Does that sound right? It's been a few years.
We swapped the inside and outside oval washer thingys to get more neg camber. Is that what you mean? I also knew a guy that had shaved the washers down.
Is this the modification for the spacers? They talk of caster being increased, but not camber.
http://www.corvettefever.com/howto/40218/
Machining both spacers equally will help with camber. I had mine machined .120" thinner. In conjunction with my installation of Global West del-a-lum bushings, I now have nearly -2.0* of camber up front and my caster is still >6*
They moved the spacers front to rear to change the caster (the spacers are different thicknesses). This is not really needed IMO on later ('88 & up) C4s.
But for extra camber, the machining seems reasonable. But I still have allot of shims I can take out in there for additional camber if needed.
Steve,
Are you road racing, auto-X-ing or just driving on the road? The reason I ask is, if being used to SCCA auto X in stock or SP, then the bushings must remain in their stock locations and in their original thickness. If the car is not being used for this, then I would recommend doing it as it will make the the car more stable. I have tried it on the track and it really made the car better at high speeds.
Steve,
