Time for a rollbar
Time for a rollbar
Anybody got in recommendations for a rollbar for a 2001 Z06. Car is heading more and more closer to becoming a track car, but is still a street car as well. I'm doing HPDE events ( 6 last year) and Laguna last month. Want to keep the carpeting and I think a 4pt will suffice? Yes/No ?
I can weld (a little), so is this within the possibilty of a DIY? I've done all my on bolt-ons like swaybars, shocks, brakes/ducts, VaraRam, harness bar/belts and tunnel plate. This would seem to be much more involved. Any experiences here?
I am sure a 4 point would suffice. It seems to me that the hoop reinforcement and the back two downtubes being reinforced is a common recommendation. Good luck
Al
Al
Dont forget the diagonal down tube, Up high behind the drivers head, to down low behind the passanger. all with in the main roll hoop. Plus the horizontal tube about shoulder level for the harness.
Supporting Vendor
You should reconsider that 4 point... A roll hoop is not really adequate when you consider the speed potential of a Corvette on track...
Give your self a real chance should anything go wrong... Put a full cage in the car if you intend to track it often with slicks, suspension and power mods...
The guardrails and walls don't know the difference or differentiate between a 130 mph track day car or a fully prepped race car....
Think about it carefully.
I agree with jAPhoenix32. However, if your car must do double duty like mine and getting in and out easily and frequently is a concern- you might want to consider the R D racing unit. It is a 4 point cross braced unit and quite stout. It took me about 8 hours to install with the hardest part being removal of the trim and carpet pieces. It also has a base cross bar between the main uprights that is designed for mounting of harnesses.
Cage is best and Phoenix cage is tops, but for double duty DRM makes a nice bar which you can easily install yourself if you can weld. Better than nothing and better than a cross bar type.
I agree that Phoenix does very good work. I have a street car that I do HPDE's with as well. I couldn't make it a total race car and think that a full cage in a street car isn't all that safe either so I had a 4pt put in by Piper in VA. The advantage of it over the kits is it fits nice and tight and is about the same price when you factor in shipping and install. Mine does not prevent me from moving my seat all the way back like some of the kits do, though my Kirkey is not movable anyway.
I do not suggest getting a "bolt in" kit. Think about what type of material you are bolting too. If you know "a little" about welding, now is not the time to practice.
PM me and I'll take some pics if you want.
Regards,
Tony
Regards,
Tony
