Sparco Rev seat installed. Pictures.
This is a Sparco Rev. Not the Rev Plus. I used the Sparco base, Sparco slider, and the Sparco side plates. Did not lose any head room. I had my wife measure from my helmet to ceiling in both seats. (Stock and Rev) If anything she thought I had a tiny bit more room with the Sparco. Seat slides back and forth with no problems. The shoulder wings do not hit the door. About 1" clearance. I did have to modify the stock seat belt on the tunnel side. As you can see in one of the pictures the seat belt is much lower then if you left it stock. I also made a bracket and attach it to the Sparco base further back. With the shorter belt and mounting it back further, the seat belt fits pretty good. If your leave the belt stock, you can see how high it sits above the seat in one of the other pictures. I'm still going to use a separate lap belt. Pictures will follow when I get that done.
Steve
Steve
I had the exact same setup - seats, mounts and sliders. Made a huge difference. I thought I was the only one who could fit in a Rev Did you also get the Sparco harness bar? Mine is collecting dust.
Steve
Good luck on your install.
Show us pictures when your done.
Steve
Hey guys. Curious what model of Sparco seat this is, and what the price is? Sliders and plates?
I`m a big guy. 6'1", 285. Have always used the butler type seats in GT1 cars, making the switch to a Z06 (2001). We need a seat for sure.
Mash
Mash
The Rev is the most narrow seat Sparco makes as far as I know. Next step up is the Evo, then the Evo2. I think I paid about $579 for mine. I got all the mounting hardware, belts, etc from
http://www.speedwaremotorsports.com/
The Rev will be WAY too small for you. I'm 6'2 and a relatively lean 180 pounds, the Evo 2 is the right size for me. An Evo 3 or larger will be needed for you. Truthfully it seems like a lot of the guys that are bigger run the aluminum seats for extra room.
