Tracking a c5 with 17x11 inch rims all around?
I have a z06 & have put my Grand Sport rims on & run with no problem. Now thinking of 11x17 all around but here is the question.
Which are better the GS rears with 50mm offset or the ZR1 rears with a different offset (I don't know what it is, but it's not the same as GS)
Thanks.
Thanks.
Received 8,928 Likes
I started using the 11 inch GS offset wheels last year. I get some pavement scrubbing on a couple of turns at Watkins that I didn't get when I ran the 9.5 inchers. One thing that happens is the instant removal of inside wheel weights upon tight turns (at lock). I was backing into the garage at the Glen and heard this loud bang. Once I was in the garage I got out of the car and found the inside wheel weight from the left side wheel laying on the pavement.
Bill
Bill
I have run 17x11 GS offset (OEM) and knockoffs all around. I have not knocked a weight off - but with 315s in the front I scrub the front fenders in my FRC but clear the ZO6 ones just fine.....
If you go full lock on a full track, you have bigger problems than wheel weights.
