Will C5 rear rotors fit a C6?
My local NAPA is not showing a part# for rear brake rotors for an '05 or '06 Corvette. They do show a part number for an '04. Rotor diameter is 12". Are they the same as on the rear of a C6? Mine is a Z51 and I just bought the base C6 (non-slotted or drilled) front rotors from NAPA and need a set of rears so I can install my new Carbotech pads...
Thanks in advance
Thanks in advance
C'mon, anyone???
After searching the forum under "rotors", and "brakes" I found nothing other than that possibly the mounting brackets are different between the base C6 and the Z51 C6.
Anyone who has experience here please advise me I have an event this weekend and I'm running out of time
Base C6 rotors (aka C5 rotors) require new caliper brackets on a C6 Z51 car. The part numbers on the caliper brackets (abutments) are 12455800 and 12455799. You'll need to order 2 of each. http://www.gmpartshouse.com/
You may want to order a second set of slider pins and caliper bracket bolts if you plan to switch back and forth often. You'll also want some high-temp grease to lube the slider pin in the new brackets. I believe the washer for the caliper bracket bolts is a second part number so be sure to ask for them, too.
Are you talking about the front or the rear?
