c4 springs
Heres a chart with spring weights etc for all the years
http://www.idavette.net/hib/c4/sustunch.pdf
Hope that works - springs varied quite a bit by years and models. I'm still looking for a used 84 Z51 if anyone knows where I can find it!
Carl Johansson
A few points here:
- The FRONT springs are only interchangeable for 84-87 and 88-96 , rears work 84-96
- I have installed a 84 Z51 rear on my 96, What I noticed was a much stiffer teeth rattling ride of course, and the car is much looser in cornering , it will oversteer quite a bit. A stiffer front sway bar helped balance it back out. Also you may want to stay with a fairly soft rear sway bar as well. A stiff rear sway bar and stiff rear spring will really cause oversteer
This has been my experience with the C4, others may differ, this relates to flat tracks best.
