First timer at Autocross and Drag Racing
Hey I’m a new corvette owner and I wanted to try out these two types of racing since I have a car that is worth racing know. My car is a 06 Z51 M6 coupe stock except for I changed the tires to some KDW 2’s. I have done some research but still have some questions.
Autocross:
I am participating in my first race next Sunday at ETRSCCA Regional Autocross #1.
1. What tips/ advice could you give me?
2. What items should I bring with me?
3. Should I change anything on the car, tire pressure, oil level ect?
4. Are there any courtesies/etiquette that I should know about?
5. How should I launch the car?
6. Traction control on or off, Stability control on, competitive driving, off?
7. I read about putting caulk on the tires how do you put it on and what should I look for after a run?
Drag Racing
There is a 1/8-mile tack opening near my house (Knoxville, TN) in a few weeks and I wanted to try it out.
2. Should I change anything on the car, tire pressure, oil level ect?
3. Are there any courtesies/ etiquette that I should know about?
4. How do I do a burn out?
6. How does the staging work, I’m confused what pre staged, deep staged, ect. Are?
7. How does the tree work, when should I start letting the clutch out?
8. Traction control on or off, Stability control on, competitive driving, off?
9. What should I do between runs, let it idle, turn it off?
If any one could help me out and answer a few question I would really appreciate it. I don’t want to look like a complete retard my first time out.
Thanks Brian
Autocross:
Drag Racing
Thanks Brian
1 Post
Cruise-In VIII Veteran
I wouldn't do any changes for the autocross. I let my wife take mine to an autoscross during a weekend trip. I just checked tire pressures and told her to go have fun. Depending on how good you are at car control, I would use either comp mode, or turn it all off. All off is probably better because you need to rely on your skills, and you can learn a lot. But do whatever you feel comfortable with. Since you're new at it, you really want to get a feel for what the car can do and imprve your driving techniques, but most of all, have fun!
As a beginner, improving your driving skills will have by far the biggest impact on how fast you are. Changing things on the car really won't help, since you can't out drive it. If you want to chalk your tires, just make a line starting on the sidewall and going onto the tread. After you make a run, see how much chalk is left. This basically tells you which parts of the tire are touching the ground. This info can be used for altering wheel alignment and tire pressure.
Mlongo and BADC6 are IMO are giving you the best advice on where and how to begin. I did exactly the same thing when I got mine and it was one of the best things I could have done to help me understand the car, how it handled, and all the areas I needed to improve in to really drive this car. On the road course, drive your own race as there is no way you will be able to compete with the veterans so as hard as this will be, don't even try. Each lap your confidence and familiarity with the car will improve until you eventually find the limits your comfortable with.
At the drags, leave traction control and active handling on for the first few passes if you have never been to the drags. If you are running stock tires, go around the water box unless you have the burnout technique down pat. Even after you are comfortable running down the track, don't turn off active handling as it can save you from some ugliness. I asked the same questions and received the same answers from members on this forum who know this stuff better than I probably ever will. Good luck and have fun, but most importantly be safe.
This might seem kind of simple, but if you love your paint, you might think about adding some protection behind the wheels. Painters tape works for a lot of people.
Welcome. I'd suggest you post this in the Autocrossing and road racing section of the forum. We have some incredibly talented racers among our members (including professionals) and they are more than willing to lend a hand with questions.
You can find that section here under General Corvette Topics from the forum directory:
http://forums.corvetteforum.com/forumdisplay.php?f=23
At a minimum I'd suggest you read this sticky thread in that section titled "New to Auto-X and Roadracing? Look in here:
http://forums.corvetteforum.com/showthread.php?t=673766
This thread is an absolute "must read."
Paul
Paul
Autocross:
Autocross:
2. Bring plenty of fluids and maybe some food too. Also, bring some painter's tape for you numbers. Being it's your first time out, you don't need to pack out with racer gear. Oh, you should bring a helmet too...most events have spares to borrow, but sometimes the pickings can be slim. Also, wear some thin sole shoes, hiking or work boots are too bulky for proper pedal feel.
3. Just run your car as is and learn
4. Just pay attention and don't be afraid to ask questions. You will find most everybody at an Auto-X are great to get along with.
5. Auto-X gives you a running start at the starting timing light, there is no need to do a drag strip launch, just ease out the clutch and then punch it after it's fully engaged.
6. I recommend you use competitive driving. Turn it off later on if you feel comfortable. I can run about a second faster with it off, but at the same time, you also feel more on the edge of losing control. So I would use it as you are new, and losing it on the course isn't gonna help you any.
7. You can chalk your treaded shoulders to observe "rollover". It's probably not neccesary your first time out. Heck I don't even always do it. It's just a tool for optimizing air pressure...I would concentrate on learning the cousre instead of tweaking your air pressure.
ON EDIT: I should also add...don't go blazing around in first gear, after you take off, don't be afaid to short shift to second. After that, just leave it there and use your engines torque to carry you around the course.
Hammer
Best advice on an M6 drag racing.
Stage, pull up the E-brake, and slowly let the clutch out until you feel the car want to move a bit.
Push in the clutch and drop the E-brake.
That will keep the gear surfaces touching and won't shock the tires as much so you don't blow them off or start wheel hop.
Good luck
Good luck
Received 8,927 Likes
This is key. You have a lot better car control in 2nd.
Bill
