Searching for custom size rotors for C3/C4 hybrid.
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I've got the C4 suspension installed on my spare '69 frame, and am now trying to finish installing brakes. My plans are for Wilwoods all around (I have the four piston rears mounted, and am looking to do the same on the front). Due to the assortment of street wheels and track wheels I'm using, I need to find a custom size rotor. Can anybody direct me to a rotor source with a decent technical staff that can get me a part number or supplier if I give them the needed rotor dimensions? I've sent a couple e-mails to some of the brake places I found on the internet, but they were either unable or unwilling to do the hard work of looking through their books to see if they stocked a rotor matching my description. I'm looking for a rotor diameter of 11.75 inches (12 may work, but it will be extremely tight) with the usual 5 x 4.75 pattern, 2.8 inch pilot hole, 1 to 1.25 inch width, and, the most difficult requirement, a maximum of 2.125 inch "backspacing", for lack of the correct word. I measured the distance from the hub/rotor interface to the knuckle tie rod arm, and I have 2.18 inches to play with. I do have a small amount I could machine off the arm to add a little more space, but the above specs are what I am initially shooting for. If anyone can help me find a knowledgeable rotor source I would greatly appreciate it.
thanks,
Mike
thanks,
Mike
I've found several sources for rotors, but haven't found many with an assortment of shallow hats. I can find something close, but before I spring for the expensive stuff, I thought I'd try to see if there were any one piece OEM rotors fitting this description, or if the aftermarket has anything.
