type of brake pad and heating
I have a C5 Z06 that I use for roadracing, and am having heating problems. One front got so hot last weekend that the brake caliper paint turned maroon, and a wheel stud broke off when I removed the wheel!
Of course I'll be putting brake ducts and spindle duct holders on it now, but I was wondering if the type of pad effects heating much. I assume it's just a matter of braking power, and the stickier pads will heat more? I've been using PFC 01's, and before that carbotechs, both with AC Delco rotors. Both have overheated quite easily. I am thinking that the pad depth would effect heat capacity quite a bit also, and this last weekend my pads got pretty thin. Maybe that's why they overheated to that degree?
Any suggestions on pads?
Thanks,
Justin
Thanks,
Justin
Justin
when I used the PFC-01s I got 2 weekends out of a front set and 4-5 weekends out of a rear set. and the same with the rotors.
I now use Wilwood H pads and get 3 to 5 weekends out of the fronts and 7 or so weekends out of the rear set. I have also slighlty changed my braking style. start 50 ft sooning in long fast straights and braking zones
Yes the heat will discolor rotors and the calipers, that is the nature of heat.
When a brake pad is at 50% I change the pad. 50% pad thinkness does not mean there is 50% life left. 50% pad thickness is about 20% pad life remaining.
Some place I found some ceramic coated brake heat sheilds, these seem to help too.
Thanks,
Justin
Thanks,
Justin
Get some DRM brake ducts, Carbotechs and good fluid and you won't have any issues.
Justin
