Any C6 DE Tire Recommendations
I DE my 2006 C6 and I have been looking for some decent tires for the track. I tried Michelin Sport Cups which were extremely expensive and their performance was awful. They took forever to warm up, felt greasy, and were not worth the money.
Does anyone know of a good track tire setup that would give decent (4 to 5 DEs) tire wear for stock wheels (18 front 19 rear); or are there any low cost 17 and 18 inch wheels that will clear my Z51 rotors and calipers available? At least with 17 and 18 inch wheels I would have a choice of tires to use. Appearance of track wheels is not important.
You can do 18/18 but 17s won't clear the front brakes on a C6 Z51 car. For DEs you may want to consider "downgrading" to the cheap $28 NAPA rotors, anyway, then the 17s would clear no problem...
Go big or don't go...
As for tires, I run hoosiers, 245 or 275 front's and 295 or 325 rears. Either setup has worked well. I also have camber blocks installed and had LG put on the Z06 brake cooling ducts with a special 2.5 to 3 inch adapter for the brake ducting to the spindles. I'll post some pictures later this week...
Before the hoosiers I ran the KDWs and then mostly the SuperCar tires, I was 4-wheel sliding them around the turns (no trail braking) so I switched to Hoosiers.
I can get approximately 2.5 DEs with the hoosiers before they cord and pop. So getting 2 weekends is good. We drive 4 30minute sessions twice, so four hours total between two days or 8 sessions of 30minutes.
For what I'm doing, I don't mind spending the money on the tires, otherwise I can't drive like I want too.
JK
The C6 Z51 brakes will work with a 17" front wheel. I have them on my C5 Z06s using the O.E.M. Z06 wheels. They fit giving barely clearance for the inner wheel weights.
As you can see from this photo taken at CMP using the same rotors from two previous Road America events. As you can see the rotors and calipers do clear and visually look good.
