C5 seat studs. Anyone remove them?
I would like to put in longer bolts where the original seat studs are that hold the seat to the floor. Has anyone removed them? If so, how do you do it. I was thinking I could try to hammer them out. If not, maybe I could drill them out.
Thanks,
Steve
Thanks,
Steve
they welded in, I'm pretty sure. I would cut them flush, then drill new holes the size you need. Assuming you are using an aftermarket seat of some type, you may find you can drill the new holes for better placement (ie wider/narrower).
The front mount is so far forward, you pretty much have to build/buy a custom mount for just about any seat anyway. I made mine out of 1/4" aluminum angle from ebay.
http://shielsmasonry.com/eyeboltnutwasher.jpg
http://shielsmasonry.com/eyeboltseat.jpg
http://shielsmasonry.com/eyebolt1.jpg
http://shielsmasonry.com/eyebolt2.jpg
http://shielsmasonry.com/eyebolts3ALL.jpg
I use the bolt on the right as the standard seat bolt were to short to pass through my seat brackets and the floor
FIA belt mounts use eyelets, so I consider them strong enough. Of course the ones that came with my Schroth belts were too short, so I welded them into the frame (on the outside) and steel tub (on the inside).
thanks,
Steve
yea just tap them side to side and down then use a bolt and a washers. BFH Big F_ckin Hammer It seems crude but it works best!
CI 4-5-6-7 Veteran
BFH FTW.
Once you whack the OE bolts out there will be a hole in the floor and you will have to put in your own bolts and washers; bigger ones or taller ones, whatever. There won't be a threaded hole that you can put in a taller stud if that is what you were thinking. The seat bolt is a stud and a bigger flange that you can see under the car, it is one piece. When you whack the threaded bolt out the bigger flange comes out with it, not you got a hole in the floor.
Just got done knocking out the bolts. I put a socket underneath the car with a jack. That way the metal won't get deformed.
My steel brackets are out of 1/8" angle iron. I wonder if that's thick enough?
thanks for the help.
Steve
Steve
smitty2919 (11-17-2021)
1 Post
Cruise-In II Veteran
It is being loaded off to one side and that generates bending on the stud in at least 2 axes. In addition, the eyebolt is to the rear which creates another moment (lever arm) that is trying to pry it up. I am not trying to be mean, but I don't want to see anyone get hurt.
