QA-1 Users, Need recommendstiond for my C-4
St. Jude Donor '03 & '05
I am useing QA1's (currently have Bilstein Z51 HD shocks) this weekend at an autocross, and need what you recommend for a baseline. For the street, 6(clicks) up front and 4(clicks) in the rear is recommended. I have base FE1 springs, 425 front and I believe 220 rear? with 32mm solid front bar and 26mm solid rear and the Vette is lowered with VB&P suspension for autocross. What settings do you think I should start out at? Its fun runs, so I should be able to get a few good runs in.
St. Jude Donor '07
On another note get a little notepad to keep in the car. I use a small binder. Every time I am at an autocross or track day I write my settings down along with the pavement type and the weather. Helps me remember what works best when and were so when it is a real event and I only get 3 runs I don't have to mess with it as much. Same goes for writing down tire pressures...
