In car cam: Camera Type
I have heard the Mini Dv is the way to go as far as the camera. I am not trying to be cheap but I am going to pick up a new samsung Mini DV for free. The description is as follows:
Samsung MiniDV Camcorder
160 GM PerQs Product#: 40-1339-00
A small, powerful camcorder to catch life's moments. This go-anywhere MiniDV camcorder is loaded with features. You'll find a high-quality Schneider lens, 34x optical zoom/1200x digital zoom and a 680,000-pixel CCD that shoots at 800 x 600 for superior still images. The vibrant 2.7" LCD displays in a 16:9 aspect ratio for true-to-life images as you remember them. Includes Samsung's exclusive SD/MMC slot for storing images and USB 2.0 Pictbridge for easy printing.
These are the Specs: Digital
Recording Format Mini DV
Recording System NTSC
CCD Quantity 1
Memory Still Resolution 0.48 Megapixels
Optical Zoom 30x
CCD
CCD Quantity 1
CCD Pixels 680K pixels
LCD / Viewfinder
Display Type With LCD Panel
LCD Panel Size 2.5 in.
Color Viewfinder With Color Viewfinder
Lens
Optical Zoom 30x
Digital Zoom 1,200x
Filter Diameter 27 mm
Video Modes
Recording Speed SP LP
Image Stabilizer Digital Image Stabilizer
Audio
Audio Format 12/16 Bit PCM Digital Stereo Audio
Memory Photography
Memory Card Type SD Card Multimedia Card (MMC)
Digital Still Shot Mode With Still Shot Capability
Max Still Image Size 800 x 600
MPEG Movie Mode Resolution 720 x 480
MPEG Movie Mode With MPEG Movie Mode
Interfaces
Output Interfaces S-Video Audio (RCA) FireWire / DV / i.Link USB
Input Interfaces FireWire / DV / iLink
Microphone Type Internal External/Optional
Power Supply
Battery Type Proprietary Lithium
Battery Life 1.3 Hours
Dimensions
Width 2.09 in.
Depth 4.13 in.
Height 3.66 in.
Weight 0.77 lb.
Warranty
1 Year
Miscellaneous
Included Accessories Software USB Cable A/V Cable Hand Strap Lithium Propriety Battery AC Power Adapter Lens Cap
Release Date 11 January, 2006
MPN SCD363
UPC 36725301382
Product ID 29045847
Keep in mind this will cost me nothing but I could get something else if this is just not going to work well. I am still trying to figure out the mount but I am sure I can find something to work with the rollbar. Any information would be greatly appreciated.
Thanks,
Al
P.S Alot of this stuff is greek to me. I would like to transfer these to DVD from time to time. All the input will be well received.
CCD Quantity 1
Optical Zoom 30x
CCD
CCD Quantity 1
LCD / Viewfinder
Lens
Optical Zoom 30x
Digital Zoom 1,200x
Video Modes
Audio
Memory Photography
Interfaces
Power Supply
Dimensions
Width 2.09 in.
Depth 4.13 in.
Height 3.66 in.
Weight 0.77 lb.
Warranty
1 Year
Miscellaneous
MPN SCD363
UPC 36725301382
Product ID 29045847
Thanks,
Al
Do you want to use it for in car video? The still picture quality is really low. Also the digital zoom I have found is so poor you will never want to use it. What size storage does it have? It doesn't say! The camera I got came with a 256K storage limit witch only allowed 2 mins (if I remember correctly) of video. I had to get a different memory card, a one gig card, to hold enough to shoot 15 mins of video. My camera has a tripod mount hole in the bottem, I got a camera mount from chasecam.com that fits it very nice.
Thanks,
Al
Not that I can think of other then the bottem screw hole for the tripod mount. My in car suction cup camera mount screwed right into that making it plug and play. Very nice!
That camera will probably work fine. Make sure it loads from the top so you don't have to dismount it to change a tape. Use 63 min DV tapes on SP and you might want to get a .6 or .7 wide angle adaptor lens. Here's a mount that will work with most harness bars and roll bars.
http://www.bhphotovideo.com/bnh/cont...ughType=search
Keep the focus on infinity. If you use the auto focus you will get motion sickness from watching.
So focus on infinity and a wide angle view.
Some times the Digital recordings skip a beat or freeze frame, on a quick corner or movement of the car. Just the way it is.
ALways use new tapes, recodeing over old tapes does not work to well with movement from inside your car.
Thanks that looks like a good option for the roll bar.
miniDV is the closest to broadcast quality you can buy (other than the new HD cams). I've got two miniDV cams, and love them. However, in todays world of PSP's and Utube, quality isn't that big of a deal, and often the convenience of the new cameras that record onto flash cards etc make life easier.
I like a mini-DV camera that is low and long, with the lens low, close to the mounting point. Zoom back all the way, or get a wide-angle lense, and focus on the road ahead (infinity can be too far IMHO).
Al
If it's miniDV, storage is not a concern. Storage is on the tapes. The memory cards are for the still pics. THe still pics on that camera are very low resolution so you won't need a large memory card for those. It's probably capable of taking pics good enough for any internet use. Unless it's a very poor transport on the camcorder, tapes will normally not have a problem with the motion of a car. Same with using the tapes over again. I use the same set of tapes for every event and transfer to my computer, edit and make DVD's.
If it's FREE, what's the difference anyway? You'll have nothing to lose to try it.
I dunno, $40 + actual shipping sound fair, shipping should be less than $10. Email me at tom@deathtocones.com and I'll reply back with some pics.
Found a wide lens and im on my way to cheap in car vid! Now does the above mentioned mount have any sort of shock absorbtion qualities or should i not worry too much about it?
Al
Al
