305s on front??
305s on front??
im thinking of running stock zo6 rear wheels(18x10.5) on all 4 corners with 305/30-18 mounted for auto x. anybody have any experience doing this? any rubbing issues?
I run 275/35/18 RA1s on 18x10.5 wheels on the front on a road course and the tires rub my DRM air ducts enough that I need to put layers of duct tape on them as a sacraficial "wear bar". Don't know if you have ducts. I couldn't run 305s without spacers.
Many state they run them but I just don't see how if they have ducts. I think they might rub the frame on mine even w/o ducts.....
Rick
Rick
Not sure if these threads on similar question will be helpful..........
http://forums.corvetteforum.com/show...&highlight=305
I've run the F1 SC rears on the front and they just hit at full lock. I just tested some Hoosier 315/30-18 on 18x11 CCWs and they rub a bit at full lock also.
As for AX. Actually you need to worry more about full lock turns than track drivers. A lot of AX courses setup on runways have a turnaround cone. You'll be at or darned close to full lock.
