Proper Sub-belt install
I have a Corbeau seat and this http://www.vetteworksonline.com/cata...apbelt-bar.jpg
lapbelt bar.
If I buy a 6 pt harness, can I run both belts through the same sub-belt hole in my seat and then attach to the two tabs? Is that the right way to do it?
lapbelt bar.
I am not sure exactly what you are asking but if you have a 6pt harness you want two sub holes in the seat ideally If not then you can run both subs up the single hole in the seat. the sub mounting point is still very important. You do not want the mounting point in such a way that the hole is supporting all the weight and the sub strap is at a weird angle, I.E when the sub pulls in a straight line from the floor it needs to be basically parallel to the spine not cocked by the seat hole.
