Differences between early and late C4s?
I did a search and couldn't find what I was looking for so I'll ask away.
I've forgotten most of this stuff so refresh my memory.
I'm looking at an 86' Coupe 4+3 as a commuter car and the odd track day maybe a half dozen a year.
What are the shortcomings of the early C4s and how can they be overcome if necessary, obviously an 230 HP (when new) iron head TPI motor may need some heads and a carb and roller cam to wake up,
Correct me if I'm wrong, but the front brakes can update to 13" rotors with a simple swap and a new bracket for C5 calipers?
If the 4+3 live, fine, if not a 6 speed is a straight swap. THis car has 17" saw blades so no issue there.
No Zero Scrub but not the end of the world. Has ABS,
What else have I left out?
Evan
Evan
I think the brakes changed in 1988. From that year on, the C4 12" to 13" front brake conversion is pretty straightforward. Dunno about C5 conversion. Other than cheaper rotors, I don't see a big advantage.
There have been some C5 brake adapters in the C4 parts for sale section. Both for the pre-'88 brakes and later.
Former Vendor
I started doing track days last year with my 86 Z51 4+3. I decided to use it instead of my 99 FRC, even though its faster, because I was less concerned about hurting the 86. If I was going to go out and buy a car I think I'd look for a later one, 89 6 speeds seem popular. The amount you're going to spend for brakes and horsepower to get the 86 up to a later model are probably less than the difference in initial cost. The later aluminum head roller cam engines have more potential too. Just my two cents.
Have fun, Paul
Have fun, Paul
I'm in the midst of swapping mine over to a LSx and a T56 now.
Received 8,929 Likes
Evan
Evan
The nice thing about it is you could run the pee out of the engine without really stressing it since you couldn't rev high enough to stress the rods, bearings, etc.
When compared to my 97 C5 the 86 handled OK but the engine just couldn't get the job done. With the 97 going up the back straight the car was still accelerating when I got to the braking point and I saw speeds of 137 to 140 depending on how I entered the straight. With the Z06 I am seeing speeds of 145 at the same point.
The solution to the induction system is to go to a LT1 style injection system or a TPIS Miniram not a carb (shudder). Carbs are a pain to work with, provide poor mixture control at part throttle and subject to leaking (especially the Holley style) and I can't see why anybody would want to use them. At WOT they can equal the performance of fuel injection but anywhere else they fall short. I got rid of my last 4 barrel carb on a Vette in 1987 when I sold my 71 LS6 to get my 86. What a relief. I haven't had a fuel system issue since then.
Bill
A few of us in the C3 forum run the later aluminum diff and are using rea toe links like the C4 to cure the C3 toe steer problem. In working on the C3 a few folks found that in the early C4's the roll center was too high and was corrected in later C4 cars. Might be worth a search in the C4 section to see if this is the case and if so the cure might be as simple as relocating the rear toe bracket on the diff.
Early 86 coupes had iron cylinder heads, but you could swap in a set of later aluminum heads or even aftermarket versions. The factory TPI intake keeps the engine from delivering high RPM power. I have a ZZ3 cam, some head work and port matching in my car and power still drops off at 5200-5400 RPM. You can go with a Super Ram or other aftermarket manifold and that will help but they are expensive.
My 87 is a 4+3 car and I use it for street driving, autocross an d occasional track days. As mentioned, the key is regular maintenance for the OD unit with fluid and filter changes every 12-15K miles. The 4-speed was made by Doug Nash and it is really a Borg-Warner Super T-10. I don't use the OD on track so my car with some mild mod is pretty much limited to 125-128 on the top end. Everything I have read here says not to engage the OD unit on the track.
If the tranny in the car is not in good shape, look at the units from Keisler or Richmond Gear. The Keisler 5-speed is supposed to be a bolt in and there is a Richmond Gear 6-speed made specificilly for C4's. The prices are high ($3K or more) but they are supposed to be decent trannies. SK Speed also rebuilds the 4+3 with heavy duty parts.
For me, the stock brake 11.5" size works 'OK' for track use but I buy generic "white box" rotors thru the shop where I work and toss them after they show wear. Race-level pads for the early brakes are hard to come by but you can get Hawk HP+ for the front and rear. I run HPS pads for street use and swap to HP+ and new rotors for track use. A brake cooling duct set-up would be a big help for the stock brakes.
Make sure the PS pump and rack is in good shape. The chances are that you can blow the seals in the rack with lots of high RPM use from track use (I did). I replaced the rack with a Z51 version. I use Red Line PS fluid in my car. I don't have a PS fluid cooler and the factory Z51 cooler is hard to find. Go with an aftermarket cooler. A small 2-pass cooler and custom lines will work fine.
Suspension upgrades like larger sway bars, poly busings and good shocks will help the car handle. Vette Brakes has a nice C4 suspension package but it's pricey. Install a set of Z51 springs and shocks and larger sway bars and that should make a base FE1 car handle much better. Vette Brakes also has some good alignment specs you can use as starting points. Add an R-D Racing Camber Brace to stiffen up the front end and a good 5 or 6-point harness bar.
My acrylic top has shown some signs of additional cracking over the last couple of years and that may be due to flexing from autocross and track use. Consider the R-D Racing Targa Truss or something similar to keep the body stiff.
DRM has a bracket to adapt early C4's to the J55 or GS brakes. Not a real big deal. The VBP or DRM bias spring will help flatten the car out under hard braking. With a 3.54 gear and 25.6'' tire your top end is about 127 MPH @ 5900 rpm so usable is about 120 without OD. I have heard of some guys using the od with the clutch on track. If you had an on demand od system it would work but the OD is a bit tempermental.
Former Vendor
I haen't had any problems with my 4+3, but I don't use the OD on the track. I would definitely get a Z51, it will save you a lot of time and money changing the springs, sway bars and steering. I added a R+D camber brace, rebuilt the front end with poly bushings and lowered the car an inch. The turn-in feels much quicker now. I run Hoosier 295/30-17 A6s on the track and I can keep up with most street tired C5s in the corners, but they run away from me on the straights. I also use Hawk HP+ pads, but the stock 86 brakes aren't up to it. They get hot and fade if you're to hard on them.
Part of the fun of this for me is gradually improving the car and my driving.
Paul
Paul
