Help with SCCA classing
Old 04-13-2007, 12:06 PM
ztrips
ztrips's Avatar
Default Help with SCCA classing
I've tried to make sense of the rules, but I can't seem to find where my car fits.
1992 Corvette
383 cu in LT1 (forged internals, head work, cam)
Aluminum single mass flywheel
Custom ECM tune
long tube headers, side exhaust
Vortech blower
water injection system
stock saw blades and stock size street tires. brakes and suspension are stock for now. Possible sway bar/bushing upgrade in the future.
Can someone help?? Thanks...
Old 04-13-2007, 12:21 PM
UberR32
UberR32's Avatar
IIRC, blower and motor work put you in the most prepared class available. Just look for the largest PAX number and boom, there you go.
Old 04-13-2007, 12:59 PM
cendres
cendres's Avatar
SM2 is my guess.
Old 04-13-2007, 01:06 PM
Red5
Red5's Avatar
1992 Corvette
Custom ECM tune
Vortech blower
Blower and over displacement puts you in EM.
Old 04-13-2007, 01:20 PM
cendres
cendres's Avatar
Ouch. Time for someone to start looking at suspension and tires...
Old 04-13-2007, 01:42 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
I thought they switched the rules in SM2 to allow that.
Old 04-13-2007, 04:21 PM
XPC5R
XPC5R's Avatar
The engine mods are eligible for Street Modified 2. There is no upper displacement limit in 2007, just a 1.4 litre adder to your displacement for minimum weight calculations.
1600+ ( (displacement +1.4 for the blower) x 200 lbs/litre)
My quick math shows around 3120lbs, using 6.2L for the displacement. You should easily be over (and not a big deal at a local event)
Other things you can do in this class:
Any wheels and DOT (R) tires
Custom flares and fascias
Any bolt on suspension changes
Wings and splitters
Race seats
Old 04-13-2007, 04:44 PM
cendres
cendres's Avatar
From the 2007 SCCA rulebook, page 178:
"Regardless of the weight formulas above, no car will be required to weigh more than 2900 lbs"
Old 04-16-2007, 11:08 AM
JCD
JCD's Avatar
wow, I just poured over the 2007 rulebook and the FI requirements for SM2 are gone!
Now all I need is a blower, suspension, to learn how to drive, and Red5 is going down!!!
Old 04-17-2007, 11:55 PM
UberR32
UberR32's Avatar
Interesting thread. I checked the rulebook a year or two ago and decided that FI was not an option . . . will have to read the new rules.
Old 04-18-2007, 06:45 AM
ztrips
ztrips's Avatar
Well, this is very encouraging...
To Help with SCCA classing
Quick Reply: Help with SCCA classing
