Need Help on Kumho Tire Size
I am looking to buy a set of Kuhmo V710s for my Z06 for autocrossing this season. I have stock size rims but the only size tires I see available on Tire Rack are 315/35ZR18 for the rear and either 275/40ZR17 or 295/40ZR17 for the front. Can somebody help with the proper combination that will still fit in the wheel wells as well as preserve diameter ratios front to rear to not hose up the active handling? Thanks in advance for the help.
-Jay
-Jay
-Jay
-Jay
-Jay
-Jay
295 in the front, 315s in the rear.
-Jay
-Jay
Frank(and others), maybe you can give me some advice on the Hoosiers on a C6Z06 that is lowered on stock bolts, i.e., SCCA Solo Class SS legal. I was planning on running the 345's on the rear on OEM wheels, but have seen it aluded to on one of the forums that the 345's rub the fenders. Can you comment on that?
Also, are your camber settings you like for the track or autocross?
Thanks, Philip
(Sorry if I am keeping us off topic on Hoosier instead of Kumho. I wish Kumho had a fitment, but I am eager to try Hoosiers)
Thanks, Philip
For racing and HPDEs the recommended Hoosier is the R6. Ran those last year at HPDEs in My C6Z. Outstanding tire also.
Thanks, Philip
Thanks, Philip
If you have lots of money, you can have CCW make you wheels with the 1/4" offset built in.
I wonder why you lowered your car. The suspension/steering geometry gets all screwed up when you lower the car. Mine rides at stock height.
Good luck on your events.
Hoosier learned that lesson and corrected the problem in the A6/R6 design.
Frank Gonzalez
I ran A6's last season on my C5 Z06 with both my son and I running so the tires got double duty. Made a combined 110 runs on a single set of A6's before I corded the front tires. To say the least I was impressed and that was with a street alignment. I have never run Kumho's so I can comment on their wear but I really liked the A6s.
