Wilwood Brakes: Without "Thermlock" Pistons
Several vendors on this forum (TByrne and ECS) are offering very good prices on the Wilwood SL6 6-piston calipers (front). However, these caliper do not have the "thermlock" pistons. LGM, however, offers the thermlock pistons for an extra $400. How good are the SL6 calipers without the thermlock pistons? Is is worth it to "step up" to the Stoptech ST-40 (4-piston) brakes (front only)?
I asked a similar question here: http://forums.corvetteforum.com/show...t=thin+wilwood
I never really got a straight answer, but for the cost of the Wilwoods I ended up deciding on the 6 piston Stoptech package just recently.
will the sl-6 with thermlock pistons do the trick for a race setup? i mean, it HAS to be better than the stock calipers, but is it comparable with the other BBK's out there?
Received 8,929 Likes
I have been running the SL6 kit from LGM for two years. No Thermlock pistons. No problem with boiling the brake fluid but I never had a problem boiling it with the OEM calipers. I use either Wilwood 570 or 600+ brake fluid. Biggest advantage is consistent pedal feel due to not being sensitive to pedal taper and really thick brake pads that will last for 10 track days.
Bill
Bill
Bill
Bill
Bill
Bill
What pads are you running? Is this the setup that can be run with the OEM/NAPA rotors and stock Z06 front wheels?
Thanks,
Steve
Bill
Bill
But I do bleed every time out, do have cooling ducts (don't have spindle ducts yet).
I do suffer some knockback, but nothing a quick touch on the pedal doesn't solve. Setup definitely fits under stock Z06 wheels.
I run the stock NAPA rotors and the extra thick pads that do last forever.
What upgrades did you do to your OEM calipers?
The only thing I did with the OEM calipers was use track pads. I never boiled the fluid in those calipers although I had lots of problems with long pedal due to pad taper. The Wilwoods solved that problem.
On the street I run the Wilwood Q compound and on the track I run the Wilwood H pads and NAPA rotors with stock Z06 wheels. My 17 x 9.5 AFS GS wheels will not clear the calipers without a spacer so I went to 17 x 11 GS wheels front and rear. This also helps when it comes to buying tires since I can buy more used T1 tires.
One thing I found out over the weekend is that I may be generating more heat with this setup. Previously I have wrapped my front tie rod ends with Thermotec heat shield and that has worked very well to keep the boots from burning. While prepping the car this weekend I pulled the Thermotec loose to inspect the boots and found both of them brittle and torn. First time that has happened to me since I had one go bad 9 years ago on my 97. That was when I started using the Thermotec.
Bill
Bill
As previous LG SL6 user, I have nothing but good things about this caliper. Unfortunately, I can't tell you if the thermo-locks made a difference, compared to a non-thermolock caliper, but when it comes to brakes, I think it is worth the extra $$$ for piece of mind. I will say that the LG caliper is ROCK SOLID and I beat the crap out of them over and over again. Also, I thought the LG caliper was slightly different from a standard SL6 C5 package. The caliper is thicker which allows for thicker pads, which will also help with heat transfer.
Also, the LG kit came with SS lines. You can't re-use your C5 lines with the Wilwoods, so make sure you are comparing apples to apples. $400 becomes a lot cheaper if you have to buy 4 additional SS lines + thermolock pistons. Also, the LG package, I beleive comes with 1 set of the pads of your choice.
My advice, call LG and ask them what he includes in the total package and call the other vendor to make sure they include the same. I would bet they don't include SS lines or a set of pads!
Hey...and if in the end it's another $50...it's going to Lou. If there is anyone I don't mind paying a small premium to, it is LG. Support and stand behind their product #1
Bill
