Alignment changes for poly bushings?
Old 04-16-2007, 06:10 PM
leadfoot2
leadfoot2's Avatar
Default Alignment changes for poly bushings?
How much should I change the alignment specs when I change over to poly bushings on my '94?
Old 04-16-2007, 06:15 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I wouldn't change a thing initially, but if the decrease in deflection makes a noticable change in tire temps, you may want to take some camber out. In reality, it is hard to know how much the bushings deflect, especially when uppers and lowers are both deflecting, and how much that translates into camber loss.
Old 04-17-2007, 01:03 PM
leadfoot2
leadfoot2's Avatar
That was my initial thought also but I've seen alot of different recommendations on the subject on the Forum so wasn't sure on what to do.
Old 04-17-2007, 01:12 PM
leadfoot2
leadfoot2's Avatar
Old 04-17-2007, 04:15 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Autocross or the track?
Us C4 guys are "camber challenged" in the front.
Autocrossers run offset bushing to put more camber in.
Old 04-18-2007, 03:02 PM
leadfoot2
leadfoot2's Avatar
It's for road racing and was looking to get 1.5 - 2 deg of camber on the front. Who makes the offset bushings?
Old 04-18-2007, 03:06 PM
davidfarmer
VetteBrakes and Products
To Alignment changes for poly bushings?
Quick Reply: Alignment changes for poly bushings?
