Cordless impact wrench
I just got a new cordless 1/2" impact wrench today at Pboys. It is a 24volt with 200 ft lbs of torque and is labeled Goodyear Racing. I was leary of the specs but I told them I would return it tomorrow if it could not remove the lugs on my car. After charging it for 3 hours it took off all of the lug nuts with ease. The best part is it was on sale for 79.95 + an additional $20 rebate. Now I can change my tires with ease at the track this weekend. Just letting you guys know in case anyone needs one.
I love mine too! But I've started breaking the torque loose on the lug nuts with an old torque wrench. Then using the impact gun to take them off. I torque them down mildly with the gun. Then use the torque wrench to get to 100ft/lbs.
I tried using the gun to break the lug nuts loose. Found I was rounding the edges off and tearing them up pretty quick. Replaced the whole set over the winter. I guess it depends on how many events you do as to how long the lugs will last.
Received 8,963 Likes
Bill
Former Vendor
I got a sweet 3/8 elecetric overpriced Blue point. It is by far the best tool in the box. That and a small 90 degree drill! Blast wheels off without problems, but it's pushing it a little, so I don't do it often. When I'm at the track, breaker bar to loosen, then impact.
Randy
Randy
I have the Dewalt 18V XRP model rated to 300ft-lb, and the darn thing sometimes can't get my lugs off without banging on them quite a while. I even took it in to get checked and they said it was fine.
Am I the only one whose electric impact is a wimp?
I'm not thrilled with mine, it doesn't seem that strong and it wasn't cheap. Matter of fact the first one I bought broke on the first outing, must have been defective. This one has lasted about a year now and I've only had to use a breaker a couple of times. It is better than the cheapies though. I went through 2 cheapies (the transmissions broke on mine in about a year) before the Dewalt.
Love the avatar!
Be careful, I tried to use it putting the nuts back on. I figured I could start with the gun and finish with the torque wrench. Went too far with the gun.:o I already stripped three rear studs with the gun, then I broke them with the star wrench, while I was REMOVING them.
You should only use the gun to snug the lug nut up and then use a torque wrench with the proper setting to tighten them. As far as rounding off the lug nuts........obviously you arent using the right size socket.
Our 18V De Walts worked great for a year or so,got tired. Had rebuilt but still would not meet the orginal as new performance.Now use the 36V DeWalt,its balanced better than the Snapone 36Volt.
i do know that dewalt now has a few different models that are similar to the one i have but don't have as much torque...
I broke 3 studs before I figured to stop using the cheap *** lug nuts from House of Wheels. They work fine for waxers, but if you take your lugs on and off a lot they gall the threads. I switched to better lug aftermarket lug nuts and haven't had any problems.
Yea... another thing to watch for...
Has anyone tried Milwaukee's 18v cordless impact?
I have a Snap-on Impact that I bought back in 02', before you could buy the cheap ones that you guys are fortunate to have. Crappy thing about Snap-on is the battery's aren't secured very well, and they tend to fall off, cracking the housing. Of course Snap-on doesn't warranty the battery, but they conveniently sell new housings.
I use a DeWalt 18V cordless drill. I break the lugnuts loose with a breaker bar and us the drill (with a 1/2 socket adaptor) to spin the lugnuts off.
It's much safer putting the nuts back on since you can set the clutch to whatever setting you want. I then use a torque wrench to torque to 100#'s.
Plus at home I have a drill that I use for all the home chores.
