Harness Bar thickness
Old 04-18-2007, 06:11 PM
TransAmGT
TransAmGT's Avatar
Default Harness Bar thickness
I have a harness bar/camera mount. It is 1.79" in diameter and 5.625" in circumference. And its .064" thick made with quality STEEL. Would it be ok to use a harness on this?
Old 04-18-2007, 06:36 PM
Tintin
Cartoon Character
Support Corvetteforum!
Tintin's Avatar
If it is anchored ok, you will die from the G's it would take to break that pipe.. Use it....
Old 04-18-2007, 07:11 PM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
That is a really big "if", most harness bars fail in that regard. The end conditions are one of the most important things in any structure, it makes a really big difference.
Old 04-18-2007, 07:30 PM
TransAmGT
TransAmGT's Avatar
Well it will be anchored like most harness bars....in the stock seat belt mounts using grade 8 hardware
Old 04-18-2007, 07:35 PM
davidfarmer
davidfarmer's Avatar
that is thinner wall than minimum roll bar thickness by 30%, but as above, the likelihood of it actually breaking is small.
Old 04-18-2007, 07:42 PM
ghoffman
ghoffman's Avatar
Like most??? there are many differences in the end conditions. It is not just the fasteners, although there is no such thing as a "grade 8" metric fastener, (see chart on link below), it is about the sheet metal ends that matter.
http://hardbarusa.com/Fastener%20Grades.xls
Old 04-18-2007, 07:55 PM
TransAmGT
TransAmGT's Avatar
Here are some pics of the ends...they are 1/8" thick
Old 04-18-2007, 09:24 PM
67 fastback
67 fastback's Avatar
mine is twice that wall thickness and has an extra hole on each side (with a corisponding threaded hole in the car to avoid the bar from rotating)
To Harness Bar thickness
Quick Reply: Harness Bar thickness
