Goodyear f1 supercars vs. Nitto NT 555 RII
If I want to track my car about 10 days a year, but also put 5-10k miles on the street, which tire would you suggest and why? The Nittos seem to be slightly less expensive, but have less than half the durability rating. What differences can I expect to notice from the Nittos, as I have the supercars on my car now.
Thanks.
Jason
Thanks.
Jason
The Nittos are considerably faster, but will wear much faster like you say. I got anywhere from three to six events on a set of DRII's, depending on how hard I drove. You can probably count on about four to eight hours of track time with the Nittos. They don't wear much on the street. Put plenty of camber on both the front and rear to get more life on the track. You'll get a lot more wear on the track with a street alignment.
I've only used the supercars a few times on the track, but I bet if you drive them as hard they will also wear pretty fast. The Nittos are a nice compromise for street and track.
Justin
Justin
Supercars bite, Nittos are great on track and can be used on street. You'll prob want better seats and harness by the time you're using the nittos to their limit though. Hell, you can have my supercars if you want. I'll never put them on the car again after using the nittos.
The drawbacks of the Nittos are that since they are softer they are more likely to pick up stuff including rocks and nails. Also, they have a tendency to fling those rocks onto your finish. That's why most people tape off the areas behind the wheels when they track their cars. That's fine at the track, but do you want to do that on the street too? I just thought that I'd mention it in case you were **** about the finish on your street car.
Hammer
My records show:
-Nittos
271 track miles
11300 street miles
3 autocrosses
12 drag strip runs
-F1 SC's
252 track miles
13000 street miles
4 autocrosses
10 drag strip runs
In the end, the Nittos were bald (loud and noisy on the street) with the Goodyears still more wear to be had-maybe 5000 miles on the street.
I have very little issue with Nittos picking stuff up-they aren't as soft as the Kumho's, but yes when I came off the track or autocross with them warm...they would pick up debris.
Bottomline, one is essentially a streetable track tire while the other is just a street radial.
-Nittos
271 track miles
11300 street miles
3 autocrosses
12 drag strip runs
-F1 SC's
252 track miles
13000 street miles
4 autocrosses
10 drag strip runs
I ran the 555RII's for a bit...great tire for the track, but scary as $#@% if you are driving on the street when it rains!!! Compared to the C5 z06 f1's, the nitto's are way better...
Now, the new tires on the c6 z51 and c6 z06 are awesome. I am not sure what GY did, but even being run flats, the tires offer up TONS of grip, do not get greasy, and appear to have great wear. Granted they are $$$, but worth it. I have driven both a c6 z51 and c6 z06 at VIR so I am not pulling this one out of my a$$ Of course slicks or R6's/v710s are better, but those are not dual purpose tires.
Also, look into the michelin pilot cup tires - from what i have read, they sound great.
Personally, the new Toyo R888s look very interesting...
