Alignment: Is Toe In Positive or Negative ?
Old 04-22-2007, 10:51 AM
TooManyIDs
Support Corvetteforum!
TooManyIDs's Avatar
Default Alignment: Is Toe In Positive or Negative ?
I want to make sure the reference information in this table is accurate.
http://www.corvetteforum.net/c5/toom...6alignment.htm
I'm concerned with the following statement, "When the wheels are turned in, toe is positive ( + ). When the wheels are turned out, toe is negative ( - )."
Is it correct or backwards?
Old 04-22-2007, 11:01 AM
Slalom4me
Slalom4me's Avatar
The statement is correct.
Toe-In is denoted by a positive sign.
Old 04-22-2007, 11:11 AM
Slalom4me
Slalom4me's Avatar
Notice that the Toe values on the chart are 'Individual' or per wheel.
Total Toe will be 2 x Individual Toe.
My vote is that traditionally, toe specs were stated as Total Toe. So in
fractional inches, it was understood that unless otherwise denoted, a
front toe spec of 1/8" meant 1/16" per side.
To Alignment: Is Toe In Positive or Negative ?
Quick Reply: Alignment: Is Toe In Positive or Negative ?
