10* or 20* lay back? UltraSheild
St. Jude Donor '07
I'll be getting this http://www.racerwholesale.com/produc...c023726249f596
What do you recommend 10* or 20*? It's going in a C3
The HANS holds the helmet slightly more forward than without. I rotated the seat back in the Z to compensate for it but now the front might be a little too high. I may change the seat bottom padding a little.
Other than this issue the HANS has been very easy to live with. I never notice it when driving and it adds an additional amount of safety. IMHO an easy decision...
Get the Deluxe model.... I'm guessing like the Kirkey it has more gussets and ribs
Regards,
Tony
Regards,
Tony
20 = more hans room at the back of the neck. = tall people can get more headroom in the car. = short people do not have the knee area raised too gain hans room by tilting a 10* back. 20 is way more comfortable unless you like the 10* full upright close to the steering wheel nascar position. Also, depending on your distance to the shifter a 10* will crowd your shift more.
I am 6-2, I do like to up close and personal with the steering wheel.
I use the 10*, but also recline the back of the seat to about 20*, which allows the front part of the seat bottom to be rotated up. I also put additional padding under the seat cushion to raise my knees up a bit more.
Shifting is not a problem. The only thing I can not do is left foot brake. The steering wheel bottom gets in the way of my knee.
Guess I need a flat bottom steering wheel
St. Jude Donor '07
This won't be a real race car. My dad's fatass can't fit in a roll cage so we have to stick with a 4 point . We do have a nascar though that will have a 3 thousand dollar seat in it already.
St. Jude Donor '07
Hope you are faster than your dad....If he reads this you might have some parts missing from your car.
