Is my AFR of 13:1 ok for HPDE use?
Old 04-25-2007, 01:44 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Default Is my AFR of 13:1 ok for HPDE use?
Here's my latest dyno graph after getting tuned post cam.
Should I be fine on pump gas or add some 100 octane for summer track events?
Does't the car richen itself up as it gets hot anyway?
Any input from tuners/experienced people would be much appreciated.
Old 04-25-2007, 02:36 PM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
You should be fine. You're fattened up before peak torque and leaned out to 13 after.
If your knock sensors are active they'll pull timing if needed - I doubt they will need to. If I remember correctly - didn't Jeff at Carolina Motorsports tune your setup?
Lawdogg
Lawdogg's Avatar
I don't know it this helps much, but mine was tuned to 12.0 due to its use at hpdes. Tuner said better safe than sorry.
Old 04-25-2007, 02:37 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
13.1 is just fine. But there are a ton more things to it then just A/F.
3 gallons of race gas is cheaper then a set of pistons.
Randy
Old 04-25-2007, 02:38 PM
Last C5
Last C5's Avatar
I'm tuned at 12.7 average for HPDEs, you should be fine.
Old 04-25-2007, 03:00 PM
Cobra4B
Cobra4B's Avatar
Yep... Jeff Creech tuned it for me.
Randy
Thanks Randy... I'll throw in some 100 octane in the summers at HPDEs.
Old 04-25-2007, 03:09 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
low 13's is my goal, you are fine.
Old 04-25-2007, 05:15 PM
DoingOK
DoingOK's Avatar
Cruise-In VIII Veteran
CI VIII Car Show Winner
It's gonna explode Brian.....parts everywhere.
Old 04-25-2007, 09:12 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Old 04-26-2007, 09:10 AM
Cobra4B
Cobra4B's Avatar
Suck my back... seriously... just suck it.
Old 04-26-2007, 10:59 AM
ScaryFast
ScaryFast's Avatar
Randy
Randy, why run race gas? Unless the compression on the car is high isn't that a waste of money and a loss of power?
Old 04-26-2007, 01:11 PM
Miguels
Miguels's Avatar
Richer is safer than lean correct.
I know my car is running rich....
on the race gas question.....
Old 04-26-2007, 02:26 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
I agree, it will lose a little power. But if it lives to fight more track days then I guess it's good. When running anything on the edge it's good to have some safety, 3 gallons in a tank is worth about -5 horse power.
Hot inlet temps during long use is hard on the motor.
Did you guys know that it is ok for the gas stations to have up to a 10 percent cross contamination per pump??? So that means you can have 10 percent e85, disel, 87, 89, or even water.
Randy
Old 04-26-2007, 02:41 PM
davidfarmer
Randy, I didn't know about the 10%, but I DID know they pump all of the fuel through the same pipelines (with no definitive break in between), so mixing certainly occurs at various stages of the processes.
Even a stock car can have some detonation, especially at high temps, so a little race gas is never a bad idea. Whether it's worth the money these days, well that's another question....
Old 04-26-2007, 03:05 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Most of the problems are with the transport and storage of the gas.
Randy
Old 04-26-2007, 06:07 PM
ScaryFast
ScaryFast's Avatar
Randy
Thanks for the explanation, that's what I assumed you meant. Actually, this is something I've been wanting to talk about. If the original poster objects I can start a new thread as it's not really related...
The higher octane helps eliminate pre-ignition, but does not necessarily add power unless the engine is built for it. So my question is - what makes a higher compression engine more prone to pre-ignition and detonation, and why can't a lower compression motor get more out of higher octane?
I have a 383 motor built for track use with lots of high end power and a flat torque curve, but stock compression for longevity. It actually seemed to have more power when I ran it Saturday on 93 with a bottle of OTC octane boost. Sunday I filled up with 100 octane and it seemed to have the same or less HP...
My imprecise measureing stick is a buddy's car, we always run together and i can differentiate by how much I pulled on him on the back straight.
Old 04-26-2007, 07:12 PM
Timz06
Timz06's Avatar
Depends on how much silicon gasket maker and other junk fell into the engine during the cam change
To Is my AFR of 13:1 ok for HPDE use?
Old 04-26-2007, 07:17 PM
Timz06
Timz06's Avatar
T So my question is - what makes a higher compression engine more prone to pre-ignition and detonation, and why can't a lower compression motor get more out of higher octane?
Gases will explode at a certain compression without a spark. With a high compression engine and lower octane fuel, the fuel reaches this point before the piston is at the spark point. Adding octane basically makes the fuel less volatile, avoiding the ignition without the spark. Thus adding octane to fuel that does not need it will do nothing, the fuel will ignite when the spark reaches it.
Old 04-26-2007, 07:31 PM
kelp
kelp's Avatar
You could even lean it out a bit at lower RPMs.
13.1:1 is fine across the board, speaking of HPDEs specifically. Keep in mind stoich is 14.7:1. I datalogged mine and had "0" knock retard all over the maps. You can even try advancing your timing 5% at a time and see if you get any knock. But I would avoid race gas regardless.
Old 04-27-2007, 09:44 AM
ScaryFast
ScaryFast's Avatar
Makes sense. Thanks for the explanation.
Quick Reply: Is my AFR of 13:1 ok for HPDE use?
